Problem facing in RPM Sensing with mega2560 and LM393 Optical coupling sensor
Your new calc isn't going to work using two byte unsigned integers. You are multiplying 95 by 6000 which won't fit. I'd suggest that you return to the prior math for now.
wildbill:
Hi wildbill you are absolutely right.
so defining
unsigned long pulsesOfPeriod;[color=#222222][/color]
unsigned long the_real_RPM;
instead of
int pulsesOfPeriod;[color=#222222][/color]
int the_real_RPM;
should give plenty of room for big numbers.
if lower rpms should be measured with more precision you could use a longer timeintervall in the
if ( TimePeriodIsOver(RPM_Timer, 5000)
which means every 5 seconds which is five times longer than 1000 so the calculation has to be
the_real_RPM = pulsesOfPeriod * 3000 / TimeDifferenceSinceLastPeriod;
in your last code you calculate
the_real_RPM = pulsesOfPeriod * 6000 / TimeDifferenceSinceLastPeriod;
why 6000 ? it should be 3000 ???
best regards Stefan
best regards Stefan
StefanL38:
so defining
instead of
int the_real_RPM;
After the modification its working .
I think if time period increase ,need to multiply with 3.I tried to make the program with 2 Sec (2000Msec) Time period and its multiply with 3 that is 2000*3=6000,But its not working.By mistaken i have not deleted the value 6000 before posting.
the if-condition
if (  TimePeriodIsOver(RPM_Timer, 1000)  ) // 1000 means 1000 milliseconds = 1 second
contains the timing constant. And the comment tries to explain it
if you want a 2 second intervall which is 2000 milliseconds you would code
if (  TimePeriodIsOver(RPM_Timer, 2000)  ) // 2000 means 2000 milliseconds = 2 seconds
a more conventient way is to define another constant instead of a hard coded number and do the rpm-calculation including that constant
you can define at the top of your code outside any function to make it a global constant
const unsigned long MyIntervalInMSecs = 2000;
the if-condition is then
if (  TimePeriodIsOver(RPM_Timer, MyIntervalInMSecs )  )
then the calculation of the rpm has to be modified to
the_real_RPM = pulsesOfPeriod * 3 * MyIntervalInMSecs  /  TimeDifferenceSinceLastPeriod;
so the if-condition that does the timing and the calculation use the same value
whenever you change the number in the line
all places that need this number "Know" about the new value because you are using a constant
You can do the same thing with variables.
best regards Stefan
