Hello Arduino forum friends.
I'm having a bit of an issue finding the problem in my code. The code is for a pool solar heater with bypass system. When the solar temp is above pool temp the pump shots off and the water valve is set to feed the solar heater and heat the pool. When the solar heater temp goes equal or below pool temp the valve bypasses the solar heater.
How it currently preforms.
During power up when pool is warmer then solar regardless of valve position. Valve locates to bypass followed by activating the pump. If then solar temp increases above the pool the system switches over to solar. All good up to now. If temp switches again having the pool warmer the system doesn't do anything though it shows up in serial that the code is in bypass while loop. By cycling power the system switches over and works until it's back in solar position where it freezes again.
* 0 deg C = 24Kohm = value 182
* 100deg C = 1kohm = value 890
volatile int Manual_Auto_ByPass_Switch = 3; //Bypass switch. Auto manual control. LED indicating if bypass switch is ON
volatile int Manual_Switch_Vlv_Moto = 4; //Push button to rotate valve to next indicator position. Bypass solar or solar
volatile int Manual_Switch_Pump_Moto = 7; //Togle switch to manually activate pump
int SolPos = 5; //Valve positio sensor Set to solar pool heater
int BypassPos = 6; //Valve positio sensor Set to solar bypass
int pump = 9; //Turns on pool pump
int vlvmotor = 10; //Turns on motor to change valve position
int poolTmp = A0; //Pool temp sensor (analog input). 1-23kohm thermistor with 5kohm resistor
int solTmp = A1; //Solar temp sensor (analog input). 1-23kohm thermistor with 5kohm resistor
int poolADJ = A2; // Pot to adjust pool temp. 10kohm
int solADJ = A3; // Pot to adjust solar temp. 10kohm
volatile float solTmpVal = 0; //Stored value of solar temp
volatile float poolTmpVal = 0; //Stored value of pool temp
int SolPosVal; //Stored value of valve solar pos
int BypassPosVal; //Stored value of bypass solar pos
int Manual_Auto_ByPass_Switch_Value; //Stored value of bypass switch
int Manual_Vlv_Motor_Value; //Stored value for manual ON/OFF of valve motor
int Manual_Pump_Moto_Value; //Stored value for manual ON/OFF of pool pump
pinMode(Manual_Auto_ByPass_Switch, INPUT);
pinMode(Manual_Switch_Vlv_Moto, INPUT);
pinMode(Manual_Switch_Pump_Moto, INPUT);
pinMode(poolADJ, INPUT);
pinMode(solADJ, INPUT);
pinMode(SolPos, INPUT);
pinMode(BypassPos, INPUT);
pinMode(pump, OUTPUT);
pinMode(vlvmotor, OUTPUT);
pinMode(poolTmp, INPUT);
pinMode(solTmp, INPUT);
digitalWrite(vlvmotor, LOW);
digitalWrite(pump, LOW);
int readtemp(const int);
attachInterrupt(digitalPinToInterrupt(Manual_Auto_ByPass_Switch), ManualMode, HIGH);
solTmpVal = readtemp(solTmp,solADJ); //read temp of solar
poolTmpVal = readtemp(poolTmp,poolADJ); //read temp of pool
Serial.print(" Sol "); Serial.print(solTmpVal); Serial.print(" pool "); Serial.print(poolTmpVal);
while (solTmpVal > poolTmpVal) //when solar temp is higher then pool by 1deg start loop
Serial.println(" SolarON ");
SolPosVal = digitalRead(SolPos); //read position of solar bypass valve and store in vlvHstr
while (SolPosVal != HIGH) //while(SolPosVal != HIGH)
Serial.println(" SolarValveON ");
digitalWrite(vlvmotor, HIGH);
//for (int a=0;a<=20;a++)digitalWrite(vlvmotor, LOW);
//for (int a=0;a<=20;a++)digitalWrite(pump, HIGH);
while (poolTmpVal >= solTmpVal) //when solar temp is higher then pool by 1deg start loop
Serial.println(" SolarOFF ");
while (BypassPosVal != HIGH)
Serial.println(" BypassValveON ");
BypassPosVal = digitalRead(BypassPos); //read position of solar bypass valve and store in vlvBstr
solTmpVal = readtemp(solTmp, solADJ); //read temp of solar
poolTmpVal = readtemp(poolTmp, poolADJ); //read temp of pool
float readtemp(int temp,int adj)
float tempADJ= map(analogRead(adj),0,1023,-20.0,20.0);
float y;
float z;
for (int x = 0; x <= 2000 ; x++)
y=map(analogRead(temp),182,890,0.0,100.0);
z += y;
z = z / 2000;
z=z+tempADJ;
return z;
void ManualMode()
Manual_Auto_ByPass_Switch_Value = digitalRead(Manual_Auto_ByPass_Switch);
while (Manual_Auto_ByPass_Switch_Value == HIGH)
Manual_Vlv_Motor_Value = digitalRead(Manual_Switch_Vlv_Moto);
Manual_Pump_Moto_Value = digitalRead(Manual_Switch_Pump_Moto);
if (Manual_Vlv_Motor_Value == HIGH)
delay(10);
while ((SolPosVal != HIGH) && (BypassPosVal != HIGH))
if (Manual_Pump_Moto_Value == HIGH)
Serial.print(" Sol "); Serial.print(solTmpVal); Serial.print(" pool "); Serial.println(poolTmpVal);
else digitalWrite(pump, LOW);
I appreciate any suggestions in fixing this.
