Problem flashing to 009.
[EDIT]
I finally stumbled across this post, which I believe addresses my problem.
[/EDIT]
Hey all. I did a forum and web search before posting here. I’m trying to upgrade the firmware on my NG board so that I don’t have to push the button every time I load a sketch. I built the DAPA programmer listed on the main site, and followed directions in the forum thread linked from there (for using avrdude) that didn’t work, so I tried to use the burnpara.bat file… unfortunately, I don’t know exactly what all the parameters should be, and now I’ve bricked my arduino. Any help would be appreciated:
What should the lock bit etc be? Everywhere I look I only find examples for the ATMega8.
tools\avr\bin\uisp -dpart=ATmega168 -dprog=dapa -dlpt=0x378 --wr_lock=0xFF
tools\avr\bin\uisp -dpart=ATmega168 -dprog=dapa -dlpt=0x378 --wr_fuse_l=0xdf --wr_fuse_h=0xca
tools\avr\bin\uisp -dpart=ATmega168 -dprog=dapa -dlpt=0x378 --erase --upload --verify if=bootloader\ATMegaBOOT.hex
tools\avr\bin\uisp -dpart=ATmega168 -dprog=dapa -dlpt=0x378 --wr_lock=0xCF
C:\Documents and Settings\Administrator\Desktop\arduino-0009\bootloader>burnpara
.bat
C:\Documents and Settings\Administrator\Desktop\arduino-0009\bootloader>REM Befo
re running this for the first time, you'll need to install giveio.
C:\Documents and Settings\Administrator\Desktop\arduino-0009\bootloader>REM Unzi
p drivers\giveio.zip, then run ginstall.bat.
C:\Documents and Settings\Administrator\Desktop\arduino-0009\bootloader>cd ..
C:\Documents and Settings\Administrator\Desktop\arduino-0009>tools\avr\bin\uisp
Atmel AVR ATmega168 is found.
Writing lock bits ...
Reinitializing device
Lock Bits set to 0xff
Fuse Low Byte set to 0xdf
Fuse High Byte set to 0xca
\ATMegaBOOT.hex
Erasing device ...
Uploading: flash
Verifying: flash
flash error at address 0x1e80: file=0xc6, mem=0xff
flash error at address 0x1e81: file=0xe6, mem=0xff
flash error at address 0x1e82: file=0xd0, mem=0xff
Lock Bits set to 0xcf
C:\Documents and Settings\Administrator\Desktop\arduino-0009>cd bootloader
Thanks,
Tim
I'm pleased to announce that I finally got my board properly flashed to diecimila, installed the 104 capacitor and everything is working wonderfully.
In the interest of full disclosure, I'd like to admit why I was having problems. I hadn't noticed there was a bootloader folder, and a bootloader168 folder. I was trying to burn the m8 bootloader onto my m168! doh!
It happens I suppose. The good news is that it works, and it's a beautiful thing.
Thanks, Tim
