Hi everyone !
I use WampServer on my computer and i want to make my arduino card with ethernet shield put data in database named "automaplants".
My wamp use port 80 and i can access to data.php file from my phone, the port 80 is correctly accessible from anyone on my network but there are nothing appear in my database from my arduino.
When i write the url manually on my browser like :
"192.168.1.20:80/data.php?temperature=10.25&airhumidity=56.24$soilhumidity=0"
they work perfectly, the data has been entered in my db but nothing with my arduino card.
There is my code :
#include <DHT.h>
#include <Ethernet.h>
#define DHTPIN 2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
int moistureSensorPin = A0;
int moistureSensorValue = 0;
String moistureSensorPercentage;
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 21);
IPAddress server(192, 168, 1, 20);
EthernetClient client;
dht.begin();
Ethernet.begin(mac, ip);
float temp_hum_val[2] = {0};
moistureSensorValue = analogRead(moistureSensorPin);
if(moistureSensorValue < 95) {
moistureSensorPercentage = "0";
} else if(moistureSensorValue >= 95 && moistureSensorValue <= 190) {
moistureSensorPercentage = "10";
} else if (moistureSensorValue >= 190 && moistureSensorValue <= 285) {
moistureSensorPercentage = "20";
} else if (moistureSensorValue >= 285 && moistureSensorValue <= 380) {
moistureSensorPercentage = "30";
} else if (moistureSensorValue >= 380 && moistureSensorValue <= 475) {
moistureSensorPercentage = "40";
} else if (moistureSensorValue >= 475 && moistureSensorValue <= 570) {
moistureSensorPercentage = "50";
} else if (moistureSensorValue >= 570 && moistureSensorValue <= 665) {
moistureSensorPercentage = "60";
} else if (moistureSensorValue >= 665 && moistureSensorValue <= 760) {
moistureSensorPercentage = "70";
} else if (moistureSensorValue >= 760 && moistureSensorValue <= 855) {
moistureSensorPercentage = "80";
} else if (moistureSensorValue >= 855 && moistureSensorValue <= 900) {
moistureSensorPercentage = "90";
moistureSensorPercentage = "100";
if(client.connect(server, 80)) {
Serial.println("Connected to Web Server");
if(!dht.readTempAndHumidity(temp_hum_val)) {
// Send data to localhost URL
client.print("GET /data.php?");
client.print("temperature=");
client.print(temp_hum_val[1]);
client.print("&airhumidity=");
client.print(temp_hum_val[0]);
client.print("&soilhumidity=");
client.print(moistureSensorPercentage);
client.println(" HTTP/1.1\r\n");
// Print to serial monitor to survey returned value
Serial.print("Temperature : ");
Serial.print(temp_hum_val[1]);
Serial.println("°C");
Serial.print("Air humidity : ");
Serial.print(temp_hum_val[0]);
Serial.println("%");
Serial.print("Soil humidity : ");
Serial.print(moistureSensorPercentage);
Serial.println("Unable to fetch sensor value.");
// Close connnection to Web Server
client.stop();
Serial.println("Connection to localhost failed.");
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
delay(2000);
