Problem from datalogger to lcd
hey guys i have a problem with my project, i created data logger for ds3231 temperature sensor. I already finisih the program to make the data logger in excel format. But i have a problem on my next step. I want to show the data of data logger on lcd. For example i want to show the temperature at 10o'clock. So we need to input some codes through the keypad then the lcd will show the value of temperature at 10 o'clock. Hope somebody can help me with this. This is my program show far
#include <SD.h>
#include <SPI.h>
#include <DS3231.h>
File myFile;
DS3231  rtc(SDA, SCL);
int pinCS = 53; // Pin 10 on Arduino Uno
  pinMode(pinCS, OUTPUT);
  // SD Card Initialization
  if (SD.begin())
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
  rtc.begin();
  Serial.print(rtc.getTimeStr());
  Serial.print(",");
  Serial.println(int(rtc.getTemp()));
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    myFile.print(rtc.getTimeStr());
    myFile.print(",");
    myFile.println(int(rtc.getTemp()));
    myFile.close(); // close the file
  // if the file didn't open, print an error:
  else {
    Serial.println("error opening test.txt");
  delay(3000);
