Problem Fuzzy
i had problem about my defuzzification process… when input1 & 2 =0, output should be 0. when i change input1 & 2 it give correct output value…but when i change back to input1&2 to 0, the output hold the previous value…it did not give 0 anymore… :cold_sweat:
viva.txt (11.2 KB)
byte getvalue ()
  const byte returnVal [32] = {3, 6, 9, 13, 16, 19, 22, 25, 28, 31, 34,  38, 41, 44, 47,
                               50, 53, 56, ...etc };
  int index = (digitalRead (DS_L)<<4) | (digitalRead (DS_ML)<<3) | (digitalRead (DS_M)<< 2) | (digitalRead (DS_MR)<< 1) | digitalRead (DS_R);
  return returnVal [index];
Why write seven lines, when you can write the same thing in 140?
LOL!
AWOL:
byte getvalue ()
                              50, 53, 56, …etc };
Or return map(index, 0, 31, 3, 100);
i had made changes using your solution but the output still had a same problem like previous programming… i did not no where the wrong this program… :cold_sweat:
#include <Fuzzy.h>
#include <FuzzyComposition.h>
#include <FuzzyInput.h>
#include <FuzzyIO.h>
#include <FuzzyOutput.h>
#include <FuzzyRule.h>
#include <FuzzyRuleAntecedent.h>
#include <FuzzyRuleConsequent.h>
#include <FuzzySet.h>
define DS_L 13 //1
define DS_ML 12 //2
define DS_M 11 //3
define DS_MR 10 //4
define DS_R 9 //5
float val = 0;
float lastError = 0;
// Instantiating an object of library
Fuzzy* fuzzy = new Fuzzy();
FuzzySet* negative = new FuzzySet(-0.44, -0.44, -0.44, 0);
FuzzySet* zero = new FuzzySet(-0.44, 0, 0, 0.53);
FuzzySet* positive = new FuzzySet(0, 0.53, 0.53, 0.53);
FuzzySet* negatif = new FuzzySet(-0.97, -0.97, -0.97, 0);
FuzzySet* kosong = new FuzzySet(-0.97, 0, 0, 0.97);
FuzzySet* positif = new FuzzySet(0, 0.97, 0.97, 0.97);
void setup(){
pinMode(DS_L,INPUT);
pinMode(DS_ML,INPUT);
pinMode(DS_M,INPUT);
pinMode(DS_MR,INPUT);
pinMode(DS_R,INPUT);
// FuzzyInput
FuzzyInput* error = new FuzzyInput(1);
error->addFuzzySet(negative);
error->addFuzzySet(zero);
error->addFuzzySet(positive);
fuzzy->addFuzzyInput(error);
// FuzzyInput
FuzzyInput* derror = new FuzzyInput(2);
derror->addFuzzySet(negatif);
derror->addFuzzySet(kosong);
derror->addFuzzySet(positif);
fuzzy->addFuzzyInput(derror);
// FuzzyOutput
FuzzyOutput* motors = new FuzzyOutput(1);
FuzzySet* HLeft = new FuzzySet(-1.50, -1.00, -1.00, -0.50);
motors->addFuzzySet(HLeft);
FuzzySet* SLeft = new FuzzySet(-1.00, -0.50, -0.50, 0);
motors->addFuzzySet(SLeft);
FuzzySet* Straight = new FuzzySet(-0.50, 0, 0, 0.50);
motors->addFuzzySet(Straight);
FuzzySet* SRight = new FuzzySet(0, 0.50, 0.50, 1.00);
motors->addFuzzySet(SRight);
FuzzySet* HRight = new FuzzySet(0.50, 1.00, 1.00, 1.50);
motors->addFuzzySet(HRight);
fuzzy->addFuzzyOutput(motors);
// Building FuzzyRule
FuzzyRuleAntecedent* iferrornegativeAndderrornegatif = new FuzzyRuleAntecedent();
iferrornegativeAndderrornegatif->joinWithAND(negative, negatif);
FuzzyRuleConsequent* thenmotorsHRight = new FuzzyRuleConsequent();
thenmotorsHRight->addOutput(HRight);
FuzzyRule* fuzzyRule1 = new FuzzyRule(1, iferrornegativeAndderrornegatif, thenmotorsHRight);
fuzzy->addFuzzyRule(fuzzyRule1);
FuzzyRuleAntecedent* iferrornegativeAndderrorkosong = new FuzzyRuleAntecedent();
iferrornegativeAndderrorkosong->joinWithAND(negative, kosong);
FuzzyRuleAntecedent* iferrornegativeAndderrorpositif = new FuzzyRuleAntecedent();
iferrornegativeAndderrorpositif->joinWithAND(negative, positif);
FuzzyRuleAntecedent* iferrorzeroAndderrornegatif = new FuzzyRuleAntecedent();
iferrorzeroAndderrornegatif->joinWithAND(zero, negatif);
FuzzyRuleConsequent* thenmotorsSRight = new FuzzyRuleConsequent();
thenmotorsSRight->addOutput(SRight);
FuzzyRule* fuzzyRule2 = new FuzzyRule(2, iferrornegativeAndderrorkosong, thenmotorsSRight);
fuzzy->addFuzzyRule(fuzzyRule2);
FuzzyRule* fuzzyRule3 = new FuzzyRule(3, iferrornegativeAndderrorpositif, thenmotorsSRight);
fuzzy->addFuzzyRule(fuzzyRule3);
FuzzyRule* fuzzyRule4 = new FuzzyRule(4, iferrorzeroAndderrornegatif, thenmotorsSRight);
fuzzy->addFuzzyRule(fuzzyRule4);
FuzzyRuleAntecedent* iferrorzeroAndderrorkosong = new FuzzyRuleAntecedent();
iferrorzeroAndderrorkosong->joinWithAND(zero, kosong);
FuzzyRuleConsequent* thenmotorsStraight = new FuzzyRuleConsequent();
thenmotorsStraight->addOutput(Straight);
FuzzyRule* fuzzyRule5 = new FuzzyRule(5, iferrorzeroAndderrorkosong, thenmotorsStraight);
fuzzy->addFuzzyRule(fuzzyRule5);
FuzzyRuleAntecedent* iferrorzeroAndderrorpositif = new FuzzyRuleAntecedent();
iferrorzeroAndderrorpositif->joinWithAND(zero, positif);
FuzzyRuleAntecedent* iferrorpositiveAndderrornegatif = new FuzzyRuleAntecedent();
iferrorpositiveAndderrornegatif->joinWithAND(positive, negatif);
FuzzyRuleAntecedent* iferrorpositiveAndderrorkosong = new FuzzyRuleAntecedent();
iferrorpositiveAndderrorkosong->joinWithAND(positive, kosong);
FuzzyRuleConsequent* thenmotorsSLeft = new FuzzyRuleConsequent();
thenmotorsSLeft->addOutput(SLeft);
FuzzyRule* fuzzyRule6 = new FuzzyRule(6, iferrorzeroAndderrorpositif, thenmotorsSLeft);
fuzzy->addFuzzyRule(fuzzyRule6);
FuzzyRule* fuzzyRule7 = new FuzzyRule(7, iferrorpositiveAndderrornegatif, thenmotorsSLeft);
fuzzy->addFuzzyRule(fuzzyRule7);
FuzzyRule* fuzzyRule8 = new FuzzyRule(8, iferrorpositiveAndderrorkosong, thenmotorsSLeft);
fuzzy->addFuzzyRule(fuzzyRule8);
FuzzyRuleAntecedent* iferrorpositiveAndderrorpositif = new FuzzyRuleAntecedent();
iferrorpositiveAndderrorpositif->joinWithAND(positive, positif);
FuzzyRuleConsequent* thenmotorsHLeft = new FuzzyRuleConsequent();
thenmotorsHLeft->addOutput(HLeft);
FuzzyRule* fuzzyRule9 = new FuzzyRule(9, iferrorpositiveAndderrorpositif, thenmotorsHLeft);
fuzzy->addFuzzyRule(fuzzyRule9);
getvalue();
float error = val - 0.4688;
float derror = error - lastError;
lastError = error;
Serial.print(“Value:”);
Serial.println(val);
Serial.print(“Error:”);
Serial.println(error);
Serial.print(“Derror:”);
Serial.println(derror);
fuzzy->setInput(1,error);
fuzzy->setInput(2,derror);
fuzzy->fuzzify();
Serial.print("Error: “);
Serial.print(negative->getPertinence());
Serial.print(”, “);
Serial.print(zero->getPertinence());
Serial.print(”, ");
Serial.println(positive->getPertinence());
Serial.print("Derror: “);
Serial.print(negatif->getPertinence());
Serial.print(”, “);
Serial.print(kosong->getPertinence());
Serial.print(”, ");
Serial.println(positif->getPertinence());
float motors = fuzzy->defuzzify(1);
Serial.print("Motors: ");
Serial.println(motors);
void getvalue()
float returnVal [32] = {0.0313, 0.0625, 0.0938, 0.1250, 0.1563, 0.1875, 0.2188, 0.2500, 0.2813, 0.3125, 0.3438, 0.3750, 0.4063, 0.4375, 0.4688,
0.5000, 0.5313, 0.5625, 0.5938, 0.6250, 0.6563, 0.6875, 0.7188, 0.7500, 0.7813, 0.8125, 0.8438, 0.8750, 0.9063, 0.9375, 0.9688, 1.0000};
val = returnVal [index];
anybody know how to use this http://www.makeproto.com/projects/fuzzy/matlab_arduino_FIST/index.php i did not know how to put it into programming.. maybe some tutorial could be good for me..
Shorter still.
uncompiled, untested
float getvalue()
  return (float)(index + 1) / 32.0;
