Problem GET Request Server esp8266
Hello
After a view runs (1-3) of the ServerDate() void i get "TCP connection failed". Can somebody help me?
#include <ESP8266WiFi.h>
const char* ssid     = "*********";
const char* password = ""*********";";
const char* host = "myServer.com";
const char* streamId   = "STREAMID";
const char* privateKey = "MEINSCHLUESSEL";
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
void ServerData(){
  int value = 0;
  WiFiClient client;
  if (!client.connect(host, 80)) {
    Serial.println("TCP connection failed");
    return;
  String url = "/input.php";
  url += "?key=";
  url += privateKey;
  url += "&value=";
  url += value;
  // This will send the request to the server
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  unsigned long timeout = millis();
  while (client.available() == 0) {
    if (millis() - timeout > 5000) {
      Serial.println(">>> TCP Client Timeout !");
      client.stop();
      return;
  // Read all the lines of the reply from server and print them to Serial
  while(client.available()){
    String line = client.readStringUntil('\r');
    Serial.print(line);
  ServerData();
  delay(10000);
Where do you close the connection? How many simultaneous, open connections do you think you can have?
I added
    Serial.print(line);
  client.stop();
But the same problem.
Sorry. I'm a beginner in Internet connections.
When you read all the data that the server sends back, the connection will be closed automatically. So, read all the data. There might even be some clues in the data.
client.connected() and client.available() are interesting functions.
Do you mean there is a problem in my php?
I used a very simple php, that send me the variables back. Only for test.
I use the example fro arduino. But there is a problem.
<?php
$private_key = $_GET['key'];
$value = $_GET['value'];
echo $private_key . '
' . $value . '\r';
