Problem get signal data remote Ac Acson international
I have a problem, I want to get the ac acson international remote data signal, why every time I finish uploading IRrecvDump, the serial monitor runs the signal data by itself without pressing the remote control button. I use IRrecvDumpV2 and the same thing happens. My project is ardunio mega control ac. I am new to the field of ardunio. Please Help me solve this problem.
/* Modified by Chris Targett
* Now includes more protocols
* Novemeber 2011
* IRremote: IRrecvDump - dump details of IR codes with IRrecv
* An IR detector/demodulator must be connected to the input RECV_PIN.
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
* Modified by Chris Targett to speed up the process of collecting
* IR (HEX and DEC) codes from a remote (to put into and .h file)
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
// Dumps out the decode_results structure.
// Call this after IRrecv::decode()
// void * to work around compiler issue
//void dump(void *v) {
//  decode_results *results = (decode_results *)v
void dump(decode_results *results) {
  int count = results->rawlen;
  if (results->decode_type == UNKNOWN) {
    Serial.print("Unknown encoding: ");
    else if (results->decode_type == NEC) {
    Serial.print("Decoded NEC: ");
  else if (results->decode_type == SONY) {
    Serial.print("Decoded SONY: ");
  else if (results->decode_type == RC5) {
    Serial.print("Decoded RC5: ");
  else if (results->decode_type == RC6) {
    Serial.print("Decoded RC6: ");
  else if (results->decode_type == SAMSUNG) {
    Serial.print("Decoded SAMSUNG: ");
  else if (results->decode_type == JVC) {
    Serial.print("Decoded JVC: ");
  else if (results->decode_type == PANASONIC) {
    Serial.print("Decoded Panasonic: ");
  Serial.print(results->value, HEX);
  Serial.print("(");
  Serial.print(results->bits, DEC);
  Serial.println(" bits)");
  Serial.print("#define Something_DEC ");
  Serial.println(results->value, DEC);
  Serial.print("#define Something_HEX ");
  Serial.println(results->value, HEX);
  Serial.print("Raw (");
  Serial.print(count, DEC);
  Serial.print("): ");
  for (int i = 0; i < count; i++) {
    if ((i % 2) == 1) {
      Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
    else {
      Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
    Serial.print(" ");
  Serial.println("");
  if (irrecv.decode(&results)) {
    dump(&results);
    irrecv.resume(); // Receive the next value
error
C:\Users\Arep\AppData\Local\Temp\arduino_modified_sketch_203611\IRrecvDumpV2.ino: In function 'void loop()':
C:\Users\Arep\AppData\Local\Temp\arduino_modified_sketch_203611\IRrecvDumpV2.ino:85:29: warning: 'bool IRrecv::decode(decode_results*)' is deprecated: Please use IrReceiver.decode() without a parameter and IrReceiver.decodedIRData.<fieldname> . [-Wdeprecated-declarations]
In file included from C:\Program Files (x86)\Arduino\libraries\IRremote/IRremote.hpp:221:0,
                 from C:\Program Files (x86)\Arduino\libraries\IRremote/IRremote.h:10,
                 from C:\Users\Arep\AppData\Local\Temp\arduino_modified_sketch_203611\IRrecvDumpV2.ino:16:
C:\Program Files (x86)\Arduino\libraries\IRremote/IRReceive.hpp:1456:6: note: declared here
 bool IRrecv::decode(decode_results *aResults) {
Sketch uses 6886 bytes (2%) of program storage space. Maximum is 253952 bytes.
Global variables use 825 bytes (10%) of dynamic memory, leaving 7367 bytes for local variables. Maximum is 8192 bytes.
this error still get done uploading
IRrecvDumpV2
// Include the IRremote library header
// Tell IRremote which Arduino pin is connected to the IR Receiver (TSOP4838)
int recvPin = 11;
IRrecv irrecv(recvPin);
// Configure the Arduino
void  setup ( )
  Serial.begin(9600);   // Status message will be sent to PC at 9600 baud
// Display IR code
void  ircode (decode_results *results)
  // Panasonic has an Address
    Serial.print(results->address, HEX);
    Serial.print(":");
  // Print Code
// Display encoding type
void  encoding (decode_results *results)
  switch (results->decode_type) {
    default:
    case UNKNOWN:      Serial.print("UNKNOWN");       break ;
    case NEC:          Serial.print("NEC");           break ;
    case SONY:         Serial.print("SONY");          break ;
    case RC5:          Serial.print("RC5");           break ;
    case RC6:          Serial.print("RC6");           break ;
    case DISH:         Serial.print("DISH");          break ;
    case SHARP:        Serial.print("SHARP");         break ;
    case JVC:          Serial.print("JVC");           break ;
    case SAMSUNG:      Serial.print("SAMSUNG");       break ;
    case LG:           Serial.print("LG");            break ;
    case WHYNTER:      Serial.print("WHYNTER");       break ;
    case PANASONIC:    Serial.print("PANASONIC");     break ;
    case DENON:        Serial.print("Denon");         break ;
// Dump out the decode_results structure.
void  dumpInfo (decode_results *results)
  // Check if the buffer overflowed
  if (results->overflow) {
    Serial.println("IR code too long. Edit IRremoteInt.h and increase RAWLEN");
    return;
  // Show Encoding standard
  Serial.print("Encoding  : ");
  encoding(results);
  Serial.println("");
  // Show Code & length
  Serial.print("Code      : ");
  ircode(results);
  Serial.print(" (");
void  dumpRaw (decode_results *results)
  // Print Raw data
  Serial.print("Timing[");
  Serial.print(results->rawlen-1, DEC);
  Serial.println("]: ");
  for (int i = 1;  i < results->rawlen;  i++) {
    unsigned long  x = results->rawbuf[i] * USECPERTICK;
    if (!(i & 1)) {  // even
      Serial.print("-");
      if (x < 1000)  Serial.print(" ") ;
      if (x < 100)   Serial.print(" ") ;
      Serial.print(x, DEC);
    } else {  // odd
      Serial.print("     ");
      Serial.print("+");
      if (i < results->rawlen-1) Serial.print(", "); //',' not needed for last one
    if (!(i % 8))  Serial.println("");
  Serial.println("");                    // Newline
void  dumpCode (decode_results *results)
  // Start declaration
  Serial.print("unsigned int  ");          // variable type
  Serial.print("rawData[");                // array name
  Serial.print(results->rawlen - 1, DEC);  // array size
  Serial.print("] = {");                   // Start declaration
  // Dump data
    Serial.print(results->rawbuf[i] * USECPERTICK, DEC);
    if ( i < results->rawlen-1 ) Serial.print(","); // ',' not needed on last one
    if (!(i & 1))  Serial.print(" ");
  // End declaration
  Serial.print("};");  //
  // Comment
  Serial.print("  // ");
  encoding(results);
  Serial.print(" ");
  ircode(results);
  // Newline
  Serial.println("");
  // Now dump "known" codes
  if (results->decode_type != UNKNOWN) {
    // Some protocols have an address
      Serial.print("unsigned int  addr = 0x");
      Serial.println(";");
    // All protocols have data
    Serial.print("unsigned int  data = 0x");
// The repeating section of the code
void  loop ( )
  decode_results  results;        // Somewhere to store the results
  if (irrecv.decode(&results)) {  // Grab an IR code
    dumpInfo(&results);           // Output the results
    dumpRaw(&results);            // Output the results in RAW format
    dumpCode(&results);           // Output the results as source code
    Serial.println("");           // Blank line between entries
    irrecv.resume();              // Prepare for the next value
error
C:\Users\Arep\AppData\Local\Temp\arduino_modified_sketch_583733\IRrecvDumpV2.ino: In function 'void loop()':
C:\Users\Arep\AppData\Local\Temp\arduino_modified_sketch_583733\IRrecvDumpV2.ino:167:29: warning: 'bool IRrecv::decode(decode_results*)' is deprecated: Please use IrReceiver.decode() without a parameter and IrReceiver.decodedIRData.<fieldname> . [-Wdeprecated-declarations]
                 from C:\Users\Arep\AppData\Local\Temp\arduino_modified_sketch_583733\IRrecvDumpV2.ino:4:
Sketch uses 7134 bytes (2%) of program storage space. Maximum is 253952 bytes.
Global variables use 902 bytes (11%) of dynamic memory, leaving 7290 bytes for local variables. Maximum is 8192 bytes.
IRrecvDumpV2 still can done uploading but when try open
serial monitor it become like this
The function decode(&results)) is deprecated and may not work as expected! Just use decode() without a parameter and IrReceiver.decodedIRData.<fieldname> .
Encoding  : UNKNOWN
Code      : 8E1C1C14 (32 bits)
Timing[7]:
     + 750, -  50     + 650, - 100     +6400, - 150     + 500
unsigned int  rawData[7] = {750,50, 650,100, 6400,150, 500};  // UNKNOWN 8E1C1C14
Encoding  : UNKNOWN
Code      : 22AE7A2A (32 bits)
Timing[5]:
     + 100, - 100     + 100, - 150     +8900
unsigned int  rawData[5] = {100,100, 100,150, 8900};  // UNKNOWN 22AE7A2A
Encoding  : UNKNOWN
Code      : FCABFFBD (32 bits)
Timing[5]:
     + 350, -  50     +1600, - 100     +7300
unsigned int  rawData[5] = {350,50, 1600,100, 7300};  // UNKNOWN FCABFFBD
Encoding  : UNKNOWN
Code      : FEAC02E5 (32 bits)
Timing[5]:
     + 300, - 150     +6250, -  50     +1650
unsigned int  rawData[5] = {300,150, 6250,50, 1650};  // UNKNOWN FEAC02E5
Encoding  : UNKNOWN
Code      : FEAC02E7 (32 bits)
Timing[5]:
     + 100, - 400     + 200, - 150     +8300
unsigned int  rawData[5] = {100,400, 200,150, 8300};  // UNKNOWN FEAC02E7
Encoding  : UNKNOWN
Code      : C40BD817 (32 bits)
Timing[7]:
     + 150, - 150     + 100, -  50     +8750, -2300     +  50
unsigned int  rawData[7] = {150,150, 100,50, 8750,2300, 50};  // UNKNOWN C40BD817
Encoding  : UNKNOWN
Code      : FCABFFBF (32 bits)
Timing[5]:
     + 350, - 100     +9000, - 550     +  50
unsigned int  rawData[5] = {350,100, 9000,550, 50};  // UNKNOWN FCABFFBF
This happen without touch remote button. please help me
This is my IRremote.h
 * @file IRremote.h
 * @brief Stub for backward compatibility
#ifndef IRremote_h
#define IRremote_h
#include "IRremote.hpp"
#endif // IRremote_h
#pragma once
IRremote.hpp
 * @file IRremote.hpp
 * @brief Public API to the library.
 * @code
 * !!! All the macro values defined here can be overwritten with values,    !!!
 * !!! the user defines in its source code BEFORE the #include <IRremote.hpp> !!!
 * @endcode
 * This file is part of Arduino-IRremote https://github.com/Arduino-IRremote/Arduino-IRremote.
 * MIT License
 * Copyright (c) 2015-2021 Ken Shirriff http://www.righto.com, Rafi Khan, Armin Joachimsmeyer
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is furnished
 * to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in all
 * copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
 * INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
 * PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
 * CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
 * OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
 * For Ken Shiriffs original blog entry, see http://www.righto.com/2009/08/multi-protocol-infrared-remote-library.html
 * Initially influenced by:
 * http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1210243556
 * and http://zovirl.com/2008/11/12/building-a-universal-remote-with-an-arduino/
#ifndef IRremote_hpp
#define IRremote_hpp
#define VERSION_IRREMOTE "3.5.0"
#define VERSION_IRREMOTE_MAJOR 3
#define VERSION_IRREMOTE_MINOR 5
// activate it for all cores that does not use the -flto flag, if you get false error messages regarding begin() during compilation.
//#define SUPPRESS_ERROR_MESSAGE_FOR_BEGIN
 * If activated, BOSEWAVE, MAGIQUEST,WHYNTER and LEGO_PF are excluded in decoding and in sending with IrSender.write
//#define EXCLUDE_EXOTIC_PROTOCOLS
 *                     PROTOCOLS
 * Supported IR protocols
 * Each protocol you include costs memory and, during decode, costs time
 * Copy the lines with the protocols you need in your program before the  #include <IRremote.hpp> line
 * See also SimpleReceiver example
//#define DECODE_MAGIQUEST // This must be enabled explicitly, since it modifies the RAW_BUFFER_LENGTH from 100 to 112
#if !defined(NO_DECODER) // for sending raw only
#if (!(defined(DECODE_DENON) || defined(DECODE_JVC) || defined(DECODE_KASEIKYO) \
|| defined(DECODE_PANASONIC) || defined(DECODE_LG) || defined(DECODE_NEC) || defined(DECODE_SAMSUNG) \
|| defined(DECODE_SONY) || defined(DECODE_RC5) || defined(DECODE_RC6) || defined(DECODE_HASH) \
|| defined(DECODE_BOSEWAVE) || defined(DECODE_LEGO_PF) || defined(DECODE_WHYNTER)))
#define DECODE_DENON        // Includes Sharp
#define DECODE_JVC
#define DECODE_KASEIKYO
#define DECODE_PANASONIC    // the same as DECODE_KASEIKYO
#define DECODE_LG
#define DECODE_NEC          // Includes Apple and Onkyo
#define DECODE_SAMSUNG
#define DECODE_SONY
#define DECODE_RC5
#define DECODE_RC6
#  if !defined(EXCLUDE_EXOTIC_PROTOCOLS) // saves around 2000 bytes program space
#define DECODE_BOSEWAVE
#define DECODE_LEGO_PF
#define DECODE_WHYNTER
#  endif
#  if !defined(EXCLUDE_UNIVERSAL_PROTOCOLS)
#define DECODE_DISTANCE     // universal decoder for pulse width or pulse distance protocols - requires up to 750 bytes additional program space
#define DECODE_HASH         // special decoder for all protocols - requires up to 250 bytes additional program space
#  endif
#endif
#endif // !defined(NO_DECODER)
#if defined(DECODE_NEC) && !(~(~DECODE_NEC + 0) == 0 && ~(~DECODE_NEC + 1) == 1)
#warning "The macros DECODE_XXX no longer require a value. Decoding is now switched by defining / non defining the macro."
#endif
//#define DEBUG // Activate this for lots of lovely debug output from the IRremote core.
 *                    RECEIVING
 * The length of the buffer where the IR timing data is stored before decoding
 * 100 is sufficient for most standard protocols, but air conditioners often send a longer protocol data stream
#if !defined(RAW_BUFFER_LENGTH)
#  if defined(DECODE_MAGIQUEST)
#define RAW_BUFFER_LENGTH  112  // MagiQuest requires 112 bytes.
#  else
#define RAW_BUFFER_LENGTH  100  ///< Maximum length of raw duration buffer. Must be even. 100 supports up to 48 bit codings inclusive 1 start and 1 stop bit.
//#define RAW_BUFFER_LENGTH  750  // 750 is the value for air condition remotes.
#  endif
#endif
#if RAW_BUFFER_LENGTH % 2 == 1
#error RAW_BUFFER_LENGTH must be even, since the array consists of space / mark pairs.
#endif
 * MARK_EXCESS_MICROS is subtracted from all marks and added to all spaces before decoding,
 * to compensate for the signal forming of different IR receiver modules
 * For Vishay TSOP*, marks tend to be too long and spaces tend to be too short.
 * If you set MARK_EXCESS_MICROS to approx. 50us then the TSOP4838 works best.
 * At 100us it also worked, but not as well.
 * Set MARK_EXCESS to 100us and the VS1838 doesn't work at all.
 * The right value is critical for IR codes using short pulses like Denon / Sharp / Lego
 *  Observed values:
 *  Delta of each signal type is around 50 up to 100 and at low signals up to 200. TSOP is better, especially at low IR signal level.
 *  VS1838      Mark Excess -50 to +50 us
 *  TSOP31238   Mark Excess 0 to +50
#if !defined(MARK_EXCESS_MICROS)
// To change this value, you simply can add a line #define "MARK_EXCESS_MICROS <My_new_value>" in your ino file before the line "#include <IRremote.hpp>"
#define MARK_EXCESS_MICROS    20
#endif
 * Minimum gap between IR transmissions, to detect the end of a protocol.
 * Must be greater than any space of a protocol e.g. the NEC header space of 4500 us.
 * Must be smaller than any gap between a command and a repeat; e.g. the retransmission gap for Sony is around 24 ms.
 * Keep in mind, that this is the delay between the end of the received command and the start of decoding.
#if !defined(RECORD_GAP_MICROS)
// To change this value, you simply can add a line #define "RECORD_GAP_MICROS <My_new_value>" in your ino file before the line "#include <IRremote.hpp>"
#define RECORD_GAP_MICROS   5000 // FREDRICH28AC / LG2 header space is 9700, NEC header space is 4500
#endif
 * Threshold for warnings at printIRResult*() to report about changing the RECORD_GAP_MICROS value to a higher value.
#if !defined(RECORD_GAP_MICROS_WARNING_THRESHOLD)
// To change this value, you simply can add a line #define "RECORD_GAP_MICROS_WARNING_THRESHOLD <My_new_value>" in your ino file before the line "#include <IRremote.hpp>"
#define RECORD_GAP_MICROS_WARNING_THRESHOLD   20000
#endif
/** Minimum gap between IR transmissions, in MICROS_PER_TICK */
#define RECORD_GAP_TICKS    (RECORD_GAP_MICROS / MICROS_PER_TICK) // 221 for 1100
 * Activate this line if your receiver has an external output driver transistor / "inverted" output
//#define IR_INPUT_IS_ACTIVE_HIGH
#ifdef IR_INPUT_IS_ACTIVE_HIGH
// IR detector output is active high
#define INPUT_MARK   1 ///< Sensor output for a mark ("flash")
#else
// IR detector output is active low
#define INPUT_MARK   0 ///< Sensor output for a mark ("flash")
#endif
 *                     SENDING
 * Define to disable carrier PWM generation in software and use (restricted) hardware PWM.
#if defined(ESP32)
#define SEND_PWM_BY_TIMER       // the best and default method for ESP32
#else
//#define SEND_PWM_BY_TIMER
#endif
 * Define to use no carrier PWM, just simulate an active low receiver signal.
//#define USE_NO_SEND_PWM
#if defined(SEND_PWM_BY_TIMER) && defined(USE_NO_SEND_PWM)
#undef SEND_PWM_BY_TIMER // USE_NO_SEND_PWM overrides SEND_PWM_BY_TIMER
#warning "SEND_PWM_BY_TIMER and USE_NO_SEND_PWM are both defined -> undefine SEND_PWM_BY_TIMER now!"
#endif
 * Define to use or simulate open drain output mode at send pin.
 * Attention, active state of open drain is LOW, so connect the send LED between positive supply and send pin!
//#define USE_OPEN_DRAIN_OUTPUT_FOR_SEND_PIN
 * This amount is subtracted from the on-time of the pulses generated for software PWM generation.
 * It should be the time used for digitalWrite(sendPin, LOW) and the call to delayMicros()
 * Measured value for Nano @16MHz is around 3000, for Bluepill @72MHz is around 700, for Zero 3600
#if !defined(PULSE_CORRECTION_NANOS)
#  if defined(F_CPU)
// To change this value, you simply can add a line #define "PULSE_CORRECTION_NANOS <My_new_value>" in your ino file before the line "#include <IRremote.hpp>"
#define PULSE_CORRECTION_NANOS (48000L / (F_CPU/MICROS_IN_ONE_SECOND)) // 3000 @16MHz, 666 @72MHz
#  else
#define PULSE_CORRECTION_NANOS 600
#  endif
#endif
#include "IRremoteInt.h"
#include "private/IRTimer.hpp"
#include "IRFeedbackLED.hpp"
 * Include the sources here to enable compilation with macro values set by user program.
#include "IRReceive.hpp"
#include "IRSend.hpp"
 * Include the sources of all decoders here to enable compilation with macro values set by user program.
#if defined(DECODE_BOSEWAVE)
#include "ir_BoseWave.hpp"
#endif
#if defined(DECODE_DENON )       // Includes Sharp
#include "ir_Denon.hpp"
#endif
#if defined(DECODE_DISTANCE)     // universal decoder for pulse width or pulse distance protocols - requires up to 750 bytes additional program space
#include "ir_DistanceProtocol.hpp"
#endif
#if defined(DECODE_JVC)
#include "ir_JVC.hpp"
#endif
#if defined(DECODE_KASEIKYO) || defined(DECODE_PANASONIC)
#include "ir_Kaseikyo.hpp"
#endif
#if defined(DECODE_LEGO_PF)
#include "ir_Lego.hpp"
#endif
#if defined(DECODE_LG)
#include "ir_LG.hpp"
#endif
#if defined(DECODE_MAGIQUEST)
#include "ir_MagiQuest.hpp"
#endif
#if defined(DECODE_NEC)          // Includes Apple and Onkyo
#include "ir_NEC.hpp"
#endif
#if defined(DECODE_RC5) || defined(DECODE_RC6)
#include "ir_RC5_RC6.hpp"
#endif
#if defined(DECODE_SAMSUNG)
#include "ir_Samsung.hpp"
#endif
#if defined(DECODE_SONY)
#include "ir_Sony.hpp"
#endif
#if defined(DECODE_WHYNTER)
#include "ir_Whynter.hpp"
#endif
#include "ir_Pronto.hpp" // pronto is an universal decoder and encoder
#include "ir_Dish.hpp" // contains only sendDISH(unsigned long data, int nbits)
 * Macros for legacy compatibility
#define RAWBUF  101  // Maximum length of raw duration buffer
#define REPEAT 0xFFFFFFFF
#define USECPERTICK MICROS_PER_TICK
#define MARK_EXCESS MARK_EXCESS_MICROS
#endif // IRremote_hpp
#pragma once
the ir-remote-library has changed this year.
I don't know any details. If this code is pretty old this might be the reason why
the error message gives some advice
Please use IrReceiver.decode() without a parameter and IrReceiver.decodedIRData. .
best regards Stefan
right now my serial monitor not running like before, its empty. i press button remote still nothing happen.
int recvPin = 11;
void  setup ( )
  IrReceiver.begin(recvPin, ENABLE_LED_FEEDBACK);  // Start the receiver
// Display IR code
    Serial.print(":");
  // Print Code
    default:
    Serial.println("IR code too long. Edit IRremoteInt.h and increase RAWBUF");
    return;
  encoding(results);
  Serial.println("");
  ircode(results);
  Serial.print(" (");
  // Print Raw data
      Serial.print("-");
    } else {  // odd
      Serial.print("     ");
      Serial.print("+");
  // Dump data
  // End declaration
  // Comment
  encoding(results);
  Serial.print(" ");
  ircode(results);
  // Newline
  Serial.println("");
void  loop ( )
  if (IrReceiver.decode()) {  // Grab an IR code
my code dont have error after i change irrecv.decode(&results) to IrReceiver.decode()
thanks reply message to me, if you can give me code latest version to get signal remote AC im appreciative it.
