Problem getting a downloaded Sketch working..
Hi All,
I have downloaded a sketch for my arduino, but I can’t get it to compile correctly… I hink it has to do with the versions of the Arduino software. I am using verion 0021.
At this moment I get the error: String does not name a type.
I hope someone can find the problem… And maybe some improvements… :wink:
Here is the sketch:
thermostatduino.pde v1.0 - march 2010
Temperature control for repraps machines hot-plates
François Delègue - http://reprapide.fr
CC-GNU GPL - Creative Commons GNU / General Public License
http://creativecommons.org/licenses/GPL/2.0/deed.en
-uses TMP36 IC to measure ambiant temperature
-uses RepRap 100K thermistor (EPCOS 4085) to measure hot plate temperature
-uses relay to power on/off heating resistors
-uses 2 push buttons to set target temperature
-uses standard 2x16 LCD to display information
Imported libraries:
-Bounce (push-buttons signal cleaning)
-LiquidCrystal (LCD display)
-WString (strings manipulation)
Todo list:
-implement a third button to register target temperature
-implement a fourth button to power on/off heating resistors (instead of using setting temp buttons)
-implement red led to be installed near the hot plate, signaling if plate is hot (> 45° for example)
libraries
// #include <WString.h>
#include <LiquidCrystal.h>
#include <Bounce.h>
// #include <EEPROM.h>
setting pins
const int relayCommandPin = 2; // out
const int decreaseTempButtonPin = 3; // in
const int increaseTempButtonPin = 4; // in
const int TMP36Pin = 2; // in
const int thermistorPin = 0; // in
lcd init & string vars
LiquidCrystal lcd (7,8,9,10,11,12);
String firstLCDLine;
String secondLCDLine;
bounce init
Bounce increaseTempButton = Bounce (increaseTempButtonPin, 5);
Bounce decreaseTempButton = Bounce (decreaseTempButtonPin, 5);
temperatures vars
int targetTemp = 105;
int oldTargetTemp;
const int maximumTemp = 130;
const int minimumTemp = 10;
float currentTemperature;
float previousTemperature;
const int tempAddressIntoMemory = 0;
// delays for setting/reading target temperature
const int longDelayTime = 400; // when a button get into continuous setting temperature mode
const int shortDelayTime = 100; // delay between 2 increments or decrements (continuous setting mode)
relay vars (no to set relay all time long)
const unsigned long relayTimer = 100000;
unsigned long relayCounter;
thermistor lookup table
see http://www.reprap.org/wiki/Temperature_Sensor_2_0#Upload_firmware_to_Arduino
#define NUMTEMPS 20
// Thermistor lookup table for RepRap Temperature Sensor Boards (http://make.rrrf.org/ts)
// Made with createTemperatureLookup.py (http://svn.reprap.org/trunk/reprap/firmware/Arduino/utilities/createTemperatureLookup.py)
// ./createTemperatureLookup.py --r0=100000 --t0=25 --r1=0 --r2=4700 --beta=4066 --max-adc=1023
// r0: 100000
// t0: 25
// r1: 0
// r2: 4700
// beta: 4066
// max adc: 1023
short temptable[NUMTEMPS][2] = {
{1, 841},
{54, 255},
{107, 209},
{160, 184},
{213, 166},
{266, 153},
{319, 142},
{372, 132},
{425, 124},
{478, 116},
{531, 108},
{584, 101},
{637, 93},
{690, 86},
{743, 78},
{796, 70},
{849, 61},
{902, 50},
{955, 34},
{1008, 3}
void setup ()
pinMode (relayCommandPin, OUTPUT);
lcd.begin(16, 2);
lcd.setCursor (0, 0);
lcd.print (“Init…”);
//targetTemp = EEPROM.read (tempAddressIntoMemory);
//oldTargetTemp = targetTemp;
void loop ()
setTargetTemperature ();
setTemperatureAndRelay ();
void setTargetTemperature ()
increaseTempButton.update ();
if (increaseTempButton.read () == LOW && targetTemp < maximumTemp)
targetTemp += 1;
displayTemperaturesInformation ();
delay (longDelayTime);
while (increaseTempButton.read () == LOW && targetTemp < maximumTemp)
targetTemp += 1;
delay (shortDelayTime);
decreaseTempButton.update ();
if (decreaseTempButton.read () == LOW && targetTemp > minimumTemp)
targetTemp -= 1;
while (decreaseTempButton.read () == LOW && targetTemp > minimumTemp)
targetTemp -= 1;
void setTemperatureAndRelay ()
relayCounter ++;
if (relayCounter == relayTimer)
relayCounter = 0;
currentTemperature = getThermistanceTemperature (thermistorPin);
if (currentTemperature >= targetTemp)
digitalWrite (relayCommandPin, LOW);
digitalWrite (relayCommandPin, HIGH);
if (currentTemperature != previousTemperature)
previousTemperature = currentTemperature;
// if (oldTargetTemp != targetTemp)
// EEPROM.write (tempAddressIntoMemory, targetTemp);
// oldTargetTemp = targetTemp;
void displayTemperaturesInformation ()
firstLCDLine = "Bed “;
firstLCDLine.append (int(currentTemperature));
firstLCDLine.append (” > “);
firstLCDLine.append (targetTemp);
if (digitalRead (relayCommandPin) == HIGH)
firstLCDLine.append (” * “);
firstLCDLine.append (” ");
lcd.print (firstLCDLine);
secondLCDLine = "Amb ";
secondLCDLine.append (int(getTMP36Temperature (TMP36Pin)));
lcd.setCursor (0, 1);
lcd.print (secondLCDLine);
float getTMP36Temperature (int pin)
float temp = analogRead (pin) * .004882814;
temp = (temp - .5) * 100;
return temp;
int getThermistanceTemperature (int pin)
// see http://www.reprap.org/wiki/Temperature_Sensor_2_0#Upload_firmware_to_Arduino
int rawtemp = analogRead (pin);
int current_celsius = 0;
byte i;
for (i=1; i<NUMTEMPS; i++)
if (temptable*[0] > rawtemp)*
    int realtemp = temptable[i-1][1] + (rawtemp - temptable[i-1][0]) * (temptable_[1] - temptable[i-1][1]) / (temptable*[0] - temptable[i-1][0]);
    if (realtemp > 255)
    realtemp = 255;
    }_
    current_celsius = realtemp;
    _ break;
    // Overflow: We just clamp to 0 degrees celsius*
    * if (i == NUMTEMPS)
    {_
    _ }_
    return current_celsius;
    _}*_
What OS are you using. I just downloaded 21 on my Acer, running Windows XP 32 bit, and pasted your code into the IDE. I get some errors, but that message is not one of them.
I am using Windows 7 x64... Never had any prob's with Arduino before... ?!..
