#include <SoftwareSerial.h>
#include <DFPlayer_Mini_Mp3.h>
#include <SPI.h>
#include <Wire.h>
#include <SevSeg.h>
#define STRIP_PIN A4
#define N_LEDS 1
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, STRIP_PIN, NEO_GRB + NEO_KHZ800);
SevSeg sevseg;
const int triggerPin = A1; // Weapon Fire Pin 15
const int clipSwitch = 5; // Reload
const int selectPin = A0; // Weapon Selector Pin 14
int noAmmo = 0;
unsigned long previousMillis = 0;
unsigned long previousMillis1 = 500;
long interval = 500;
long interval1 = 60;
int LED = 3;
int laserPin = A3; // Laser Pin 17
int clipState = 0;
unsigned long start_hold;
boolean allow = false;
int HOLD_DELAY = 2000; // Sets the hold delay of switch for LED state change
int sw_laststate = LOW;
long TrackCounter = 0;
long TrackCounter1 = 0;
int selectPushCounter = 0; // counter for the number of button presses weapon #1
int selectState = 0; // current state of the button
int lastselectState = 0; // previous state of the button
int val = 0; // status input pin
int triggerPushCounter = 95; // counter for the number of button presses weapon #2
int triggerState = 1; // current state of the button
int grenadePushCounter = 5;
int grenadeState = 0;
byte numDigits = 2;
byte digitPins[] = {2, 3}; //Digit 1 - 15, Digit 2 - 16
byte segmentPins[] = {6, 7, 8, 9, 10, 11, 12, 13}; // 8-A, 9-B, 10-C, 11-D, 12-E, 13-F, 14-G, 45-DP (DO NOT USE PIN 45)
byte hardwareConfig = COMMON_CATHODE; // See README.md for options
//byte hardwareConfig = COMMON_ANODE; // See README.md for options
bool updateWithDelays = false; // Default 'false' is Recommended
bool leadingZeros = true; // Use 'true' if you'd like to keep the leading zeros
bool disableDecPoint = true; // Use 'true' if your decimal point doesn't exist or isn't connected
sevseg.begin(hardwareConfig, numDigits, digitPins, segmentPins, updateWithDelays, leadingZeros, disableDecPoint);
sevseg.setBrightness(10);
strip.begin();
strip.show();
pinMode(triggerPin, INPUT); // Fire Button
pinMode(clipSwitch, INPUT); // Reload
pinMode(selectPin, INPUT); // Select Button
pinMode(laserPin, OUTPUT); // Red Laser
pinMode(LED, OUTPUT);
randomSeed(analogRead(6));
mp3_set_serial (Serial);
delay(10);
mp3_set_volume (10);
mp3_reset();
mp3_play (19 );
// Start of Weapon Select Button
selectState = digitalRead(selectPin);
if (selectState == HIGH && sw_laststate == LOW) {
start_hold = millis();
allow = true;
if (allow == false && selectState == HIGH && sw_laststate == HIGH) {
if ((millis() - start_hold) >= HOLD_DELAY) {
allow = false;
if (allow == true && selectState == LOW && sw_laststate == LOW) {
if ((millis() - start_hold) < 700 ) {
mp3_play (12);
selectPushCounter++;
allow = false;
sw_laststate = selectState;
// End of Weapon Select Button
// ************************************ WEAPONS ***************************************
// -------------------------------- WEAPON 1 --- PULSE RIFLE --------------------------------
if (selectPushCounter == 0) {
triggerState = digitalRead(triggerPin);
clipState = digitalRead(clipSwitch);
digitalWrite(LED, LOW);
if (clipState == HIGH) // Magazine Clip Inserted
// pulse_fire_sound (); // Pulse Sound - If placed here the counter flashes rapidly. When the Trigger is pressed the sound plays
{ // and the counter counts down as as it should, but when released the counter flashes rapidy again due to the state being LOW
sevseg.setNumber(triggerPushCounter);
sevseg.refreshDisplay();
if (triggerState == HIGH)
if (currentMillis - previousMillis >= interval1)
pulse_fire_sound (); // Pulse Sound - If placed here the counter displays correctly and decreases on Trigger Push but
pulse_laser_fire ();
triggerPushCounter--; // the sound plays AFTER the button is released
while (triggerPushCounter <= -1)
triggerPushCounter++;
pulse_empty_sound ();
if (clipState == LOW)
sevseg.setNumber(noAmmo, 1);
ammo_out_sound ();
// -------------------------------- WEAPON 2 --- GRENADE LAUNCHER --------------------------------
if (selectPushCounter == 1) {
grenadeState = digitalRead(triggerPin);
sevseg.setNumber(grenadePushCounter);
if (grenadeState == HIGH)
if (currentMillis - previousMillis1 >= interval)
previousMillis1 = currentMillis;
grenade_fire_sound ();
grenadePushCounter--;
digitalWrite(LED, HIGH);
while (grenadePushCounter <= -1)
grenadePushCounter++;
grenade_out_sound ();
if (selectPushCounter > 1) {
// ********************* END 2 WEAPONS, RESTART VARIABLES *********************
// *********************************** FUNCTIONS *************************
bool pulse_empty_sound () {
if (triggerPushCounter <= 0 && digitalRead(triggerPin) == HIGH) { // if BOTH the switches read HIGH
mp3_play (20);
delay (1000);
bool grenade_out_sound () {
if (grenadePushCounter <= 0 && digitalRead(triggerPin) == HIGH) { // if BOTH the switches read HIGH
mp3_play (20);
delay (1000);
bool grenade_fire_sound () {
if (grenadePushCounter >= 0 && digitalRead(triggerPin) == HIGH) {
mp3_play (7);
bool pulse_fire_sound () {
if (triggerPushCounter >= 0)
TrackCounter = random(0, 4);
if ( TrackCounter == 0 )
mp3_play (1);
if ( TrackCounter == 1 )
mp3_play (2);
if ( TrackCounter == 2 )
mp3_play (3);
if ( TrackCounter == 3 )
mp3_play (4);
if ( TrackCounter == 4 )
mp3_play (5);
void ammo_out_sound () {
boolean play_state = digitalRead(clipSwitch);// connect Pin3 to BUSY pin of player
if (play_state == HIGH) {
mp3_play (14);
static void pulse_chase(uint32_t c) { // LED Chase Sequence
strip.updateLength(1);
strip.setBrightness(255);
for (uint16_t i = 0; i < strip.numPixels() + 5; i++) {
strip.setPixelColor(i , c); // Draw new pixel
strip.setPixelColor(i - 5, 0); // Erase pixel a few steps back
strip.show();
delay(2); // Speed
void pulse_laser_fire () {
digitalWrite(laserPin, HIGH);
delay (1);
digitalWrite(laserPin, LOW);
delay (1);
void pulse_fire () {
// pulse_chase(strip.Color(255, 0, 0)); // Red
// strip.setPixelColor(1, 255, 0, 0);
// strip.show();
// delay (1);
// strip.setPixelColor(1, 0, 0, 0);
// strip.show();
// delay (1);
