Problem getting the bits of a bool [32] into an unsigned long int.
Hi guys,
I’m having trouble in transforming the 1’s and 0’s of a boolean vector into a variable.
My code is as follows:
bool bits[32];
unsigned long int ulbits = 0;
//some commands that give some value to the vector
for (int i = 0; i < 32; i++) {
      ulbits |= bits[i] << i;
      Serial.print(bits[31-i]);
Serial.println("");
Serial.println(ulbits, BIN);
Serial.println("");
In the Monitor:
00101010101010101010101010100000
11111111111111111010101010100000
I noticed that the 16 LSB of ulbits went out correctly, but all the rest was 1. What’s wrong and how can I make that variable have the same binary value as the vector?
Thank you very much!
bits[i] << i
Is evaluated as an “int” which is 16 bits wide on an eight bit Arduino.
Obviously, you can’t represent a 32 bit number in 16 bits.
Use a cast to promote “bits[ i ]” to unsigned long.
Thank you, AWOL, I'll try to do that next time and let you know if it went well! :smiley:
Thanks for your help, it worked!
But what I don’t get is why it works in CodeBlocks like this:
#include <stdio.h>
#include <stdbool.h>
int main()
    bool bits[32] = {1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0};
    int i = 0;
    while(i < 32){
        printf("%d", bits[31-i]);
        i++;
    printf("\n%lu",ulbits);
    return 0;
while in Arduino it only works when I use unsigned long int instead of bool in the code below:
  bool bits[32] = {1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0};
  int i = 0;
  while (i < 32) {
    Serial.print(bits[31 - i]);
    i++;
  Serial.println("");
  while(1){}
Anyway, thanks a lot! :smiley:
Because not all "int"s are equal (or at least, not all the same size)
