I've got the MySQL connector working in my project, but just writing dummy data.
I've got a clunky way to get the values from a few float values from temp sensors, but I'm able to get a string out the end that is what the SQL line should be, but when I put that variable in the MySQL command, it fails with the message
_2014_08_14.ino: In function 'void LogData()':
_2014_08_14:433: error: no matching function for call to 'Connector::cmd_query(String&)'
C:\Users\Matt\Documents\Arduino\libraries\mysql/mysql.h:121: note: candidates are: boolean Connector::cmd_query(const char*)
This works
my_conn.cmd_query("INSERT INTO brew master.fermenterlog VALUES ('Log Data', NULL, NULL, NULL, NULL, NULL)");
But this doesn't
my_conn.cmd_query(INSERT_SQL);
Here's how I'm building that INSERT_SQL string. Any help on how to better do that would be great.
void LogData() {
FermenterID = String("MattConical");
CurrentMode = String("Cooling");
Serial.print("SetTemp ");
Serial.println(SetTemp);
Serial.print("CurrentTempBeer ");
Serial.println(CurrentTempBeer);
//Convert Current Beer Temp to 2 decimal string
CurrentTempBeerInt = CurrentTempBeer * 100;
char CurrentTempBeerStringRaw[5];
String str;
str=String(CurrentTempBeerInt);
str.toCharArray(CurrentTempBeerStringRaw,5);
CurrentTempBeerString = String(CurrentTempBeerStringRaw);
char CurrentTempBeerStringChar1 = CurrentTempBeerString.charAt(0);
char CurrentTempBeerStringChar2 = CurrentTempBeerString.charAt(1);
char CurrentTempBeerStringChar3 = CurrentTempBeerString.charAt(2);
char CurrentTempBeerStringChar4 = CurrentTempBeerString.charAt(3);
CurrentTempBeerString = String("");
CurrentTempBeerString += CurrentTempBeerStringChar1;
CurrentTempBeerString += CurrentTempBeerStringChar2;
CurrentTempBeerString += ".";
CurrentTempBeerString += CurrentTempBeerStringChar3;
CurrentTempBeerString += CurrentTempBeerStringChar4;
//Convert Current Set Temp to 2 decimal string
CurrentSetTempInt = SetTemp * 100;
char SetTempStringRaw[5];
String str2;
str2=String(CurrentSetTempInt);
str2.toCharArray(SetTempStringRaw,5);
SetTempString = String(SetTempStringRaw);
char SetTempStringChar1 = SetTempString.charAt(0);
char SetTempStringChar2 = SetTempString.charAt(1);
char SetTempStringChar3 = SetTempString.charAt(2);
char SetTempStringChar4 = SetTempString.charAt(3);
SetTempString = String("");
SetTempString += SetTempStringChar1;
SetTempString += SetTempStringChar2;
SetTempString += ".";
SetTempString += SetTempStringChar3;
SetTempString += SetTempStringChar4;
INSERT_SQL = String("INSERT INTO `brew master`.fermenterlog VALUES ('");
INSERT_SQL += FermenterID;
INSERT_SQL += "',NULL,'";
INSERT_SQL += CurrentMode;
INSERT_SQL += "','";
INSERT_SQL += CurrentTempBeerString;
INSERT_SQL += SetTempString;
INSERT_SQL += num_fails;
INSERT_SQL += "')";
Serial.println(INSERT_SQL); // prints Full SQL String
// my_conn.cmd_query("INSERT INTO `brew master`.fermenterlog VALUES ('Log Data', NULL, NULL, NULL, NULL, NULL)");
