problem: I can't get in AT command mode for HC-05
hi, i have a problem in accessing AT command mode for HC-05 Bluetooth
recently i found a code for to perform this task but when i send any thing there is no response
however the Bluetooth led blinking very slow 2 sec on 2 sec off
AUTHOR: Hazim Bitar (techbitar)
DATE: Aug 29, 2013
LICENSE: Public domain (use at your own risk)
CONTACT: techbitar at gmail dot com (techbitar.com)
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(10, 11); // RX | TX
  pinMode(9, OUTPUT);  // this pin will pull the HC-05 pin 34 (key pin) HIGH to switch module to AT mode
  digitalWrite(9, HIGH);
  Serial.println("Enter AT commands:");
  BTSerial.begin(38400);  // HC-05 default speed in AT command more
  // Keep reading from HC-05 and send to Arduino Serial Monitor
  if (BTSerial.available())
    Serial.write(BTSerial.read());
  // Keep reading from Arduino Serial Monitor and send to HC-05
  if (Serial.available())
    BTSerial.write(Serial.read());
any help will be appreciated
thank you :slight_smile:
I used
http://www.martyncurrey.com/arduino-with-hc-05-bluetooth-module-at-mode/
You can try press and hold the button switch on the BT module before powering ON BT and the release the button... (Sorry for my English) :slight_smile:
Thank you very much it was very useful
