Problem: I2C Configuration Between Two Arduinos
Hello and thank you all! Here are my codes:
Arduino Master:
#include <Wire.h>
int counter = 0;
  Wire.begin();
  Wire.beginTransmission(1);
  Wire.write(counter);
  Wire.endTransmission();
  counter++;
Arduino Slave:
#include <Wire.h>
int val = 0;
  Wire.begin(1);
  val = Wire.read();
  Serial.println(val);
My problem is that the serial monitor only prints -1 repeatedly, indicating that I'm not receiving any data (I had a while loop waiting for serial data (Wire.available()==0) but got rid of it because there was no printing going on period.
I think it might be a physical configuration thing:
I have both the A5 pins connected to a rail on my breadboard, which is connected to high via a 10k ohm resistor.
I have both the A4 pins connected to a rail on my breadboard, which is connected to high via a 10k ohm resistor.
I have the ground pins on my two Arduinos connected to each other.
I have a ground pin from my slave Arduino connected to my breadboard.
I have one 5V output pin from my slave Arduino connected to my breadboard
On the slave, you should have an onRequest event handler registered. That gets called when the master wants to talk to the slave.
I2C is not serial. That Wire.available() never reported a value greater than 0 should be a clue that the devices are not talking.
Show a picture or schematic of your setup.
This does not sound right. The I2C pins should not be connected the +V rail.
Google Nick Gammon. He wrote a nice master/slave routine for sending data between two arduinos.
hope it helps,
MaLi
