Problem IDE after windows 10 update
Since I installed a windows 10 update I started having problems with the Arduino IDE, when I try to install a library, when clicking on the item include zip library the IDE closes, it does not happen the same if I use manage libraries
Thank you.
Try reinstalling it :slight_smile: (Maybe with cleaning the settings file in between) Don't use the Windows store version.
And do you have the most updated version of Java?
Better to find a solution, but as a workaround you can always do a manual library installation instead of "Add .ZIP library":
You might get some additional information on the problem by starting the Arduino IDE by running arduino_debug.exe (which is located in the Arduino IDE installation folder) from the command line and then examining the output after the crash.
