Problem identifying a resistor value
I have problem identifying a resistor on Arduino Mega 2560 R3 (i have marked it with a red ring on the picture), i think it's R14 10k ohm on the schematic but not really shure, need to know in order to replace it.
And another question, there is a part next to the usb port that is gold and black and marked 501L on the picture (but my board is marked X505), i think it's a resettable fuse, anyone that can correct me?
To reset it i gues i remove it and resolder it with the opposide polarity?
Sorry for my bad english but it's not my native language.
I only see a ceramic decoupling capacitor there. Ceramic caps are brown, resistors are usually black with
white printing.
The cap looks to be on the input of the 5V regulator.
R3 is a quad resistor array anyway.
Refering to the schematics, it appears to be C2
Yes, its a resettable fuse, part# MF-MSMF050-2
bljardkungen:
No, it's a self resetting fuse. Just remove the load, and it will reset.
bljardkungen:
It is what's called a positive temperature coefficient (PTC) resistor. It starts out with a very low resistance, but when current goes through it it heats up based on the formula P = I2R. This heat causes the resistance to rise. Below a certain level, the heat is mild enough to not cause a large change in resistance. However, once the current goes above a certain threshold, the resistance rises out of control and severely limits the current flowing through the "fuse".
To reset the fuse, you just need to remove power and wait a few seconds for it to cool off and return to its normal (low) resistance.
Jiggy-Ninja:
Thanks for your detailed response, didn't even know fuses/resistors like that existed, really cool.
dlloyd:
That part is not on the schematic i found, i might have found the wrong one.
Do you have a link to the full one?
bljardkungen:
Click "schematics" in the post you quoted - he linked to the full schematic he pulled that from.
DrAzzy:
Missed that, thank you for your fast reply and thanks to you all for your kind and fast help :slight_smile:
It is F1 in the schematic next to the USB connector.
Jiggy-Ninja:
Probably minutes - polymer melting/recrystalization is not a sharp phase change.
