Problem implementing ultrasonic interrupt (new ping library)
I’ve had some help with the coding of an ongoing project (see previous my previous posts if you want background) which is now working, since I have tried to develop it to include an ultrasonic (SRF05) but cannot even get it to serial.print distances.
I am trying to use the new ping library and think it could be conflicting with some of the other libraries / code.
There are some other posts on here which discuss using event-driven interrupts within this library but I could not get a clear answer from it.
I have tried accessing the ultrasonic data at different baud rates, to no avail. However, with the same setup (connections) and a simple script the ultrasonic works fine.
Simply put, I am trying to have the ultrasonic cause my robot to stop and reverse when it finds an object in front of it before continuing with the program (object removed).
#include <Wire.h>
#include <NewPing.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
#include <SPI.h>
#include <Pixy.h>
#define TRIGGER_PIN  12  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     11  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    #define swap(a,b) { \
        int c = (a);    \
        (a) = (b);      \
        (b) = c;        \
Pixy pixy;
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *MotorL = AFMS.getMotor(1);
Adafruit_DCMotor *MotorR = AFMS.getMotor(2);
  Serial.begin(9600); // Open serial monitor at 115200 baud to see ping results.
  AFMS.begin();  // create with the default frequency 1.6KHz
  MotorL->setSpeed(255); // Set the speed to start, from 0 (off) to 255 (max speed)
  MotorL->run(FORWARD);// turn on motor
  MotorL->run(BACKWARD);
  MotorL->run(RELEASE);
  MotorR->setSpeed(255); // Set the speed to start, from 0 (off) to 255 (max speed)
  MotorR->run(FORWARD);// turn on motor
  MotorR->run(BACKWARD);
  MotorR->run(RELEASE);
  uint16_t blockCount;
  blockCount = pixy.getBlocks();
  Serial.print(" Blocks : ");
  Serial.print(blockCount);
  Serial.print(" ");
  const double minRequiredRatio = 0.8;
  const double maxRequiredRatio = 1.2;
  int chosenBlock = -1;
  int chosenSignature = 1;
  for (int idx = 0; idx < blockCount; ++idx)
    Block& pixyBlock = pixy.blocks[idx];
    if (pixyBlock.signature != chosenSignature)
      continue;
    int objectSize = pixyBlock.width * pixyBlock.height;
    double objectRatio = (double)pixyBlock.width / (double)pixyBlock.height;
    Serial.print("Size : ");
    Serial.print(objectSize);
    Serial.print(", ");
    Serial.print("Ratio : ");
    Serial.print(objectRatio);
    Serial.print(" ");
  const double squareTolerance = 0.5; // Adjust to suit
    double squareness = fabs(1.0 - objectRatio);
    const double minRatio = 0.8; // Adjust to suit
    const double maxRatio = 2.0; // Adjust to suit
    if (objectRatio > minRatio && objectRatio < maxRatio)
      chosenBlock = idx;
  if (chosenBlock < 0)
      Serial.println("Could not find desired object");
     return;
Block& singlePixyBlock = pixy.blocks[chosenBlock];
 int objectX = singlePixyBlock.x;
  int objectY = singlePixyBlock.y;
  Serial.print(", X Value : ");
  Serial.print(objectX);
  Serial.print(", Y Value : ");
  Serial.println(objectY);
    const int cameraWidth = 320;
  const int cameraHeight = 200;
  const int centreX = cameraWidth / 2;
  const int centreY = cameraHeight / 2;
   const int idealDistanceSize = 5000; // Adjust to suit
  const int idealDistanceTolerance = idealDistanceSize / 10; // Adjust to suit
  int objectSize = singlePixyBlock.width * singlePixyBlock.height;
  const int maxSpeed = 255;
  const int slowestSpeed = maxSpeed - 128; // Adjust to suit
  const int distLimit = 10; //Limit for obstacles (in cm)
  int dist = sonar.ping_cm();
  int centreOffset = objectX - centreX;
  int speedOffset = ((double)centreOffset / (double)centreX) * (double)(maxSpeed - slowestSpeed);
  int speedLeft = slowestSpeed - speedOffset;
  int speedRight = slowestSpeed + speedOffset;
 int motorDirection = RELEASE;
  Serial.print("objectSize: ");
  if (dist<distLimit)
    motorDirection = BACKWARD;
    Serial.print("Ping: ");
    Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
    Serial.println("cm ");
  if (objectSize < (idealDistanceSize - idealDistanceTolerance))
    motorDirection = FORWARD;
    Serial.print(" FORWARD ");
  else if (objectSize > (idealDistanceSize + idealDistanceTolerance))
    swap(speedLeft, speedRight);
    Serial.print(" BACKWARD ");
    Serial.print(" RELEASE ");
  MotorL->setSpeed(speedLeft);
  Serial.print(" MotorL: ");
  Serial.print(speedLeft);
  MotorR->setSpeed(speedRight);
  Serial.print(" MotorR: ");
  Serial.print(speedRight);
  MotorL->run(motorDirection);
  MotorR->run(motorDirection);
I can't make any sense of that. Can you please explain what you mean ?
poor terminology.
ive tried running the serial monitor at different baud rates 9600, 115200 etc, to see if makes a difference
Is this value likely to change on each pass through loop()?
An awful lot of stuff you are doing in loop() makes no sense there. The camera characteristics are not likely to change, are they?
Dump that sketch. Create one that does NOTHING but initialize the serial port, read the ping sensor, and print the value to the serial port.
Tell us EXACTLY what you see in the Serial Monitor.
PaulS:   uint16_t blockCount;   blockCount = pixy.getBlocks();
Not at the moment but could depending if I want to see more objects.
PaulS: An awful lot of stuff you are doing in loop() makes no sense there. The camera characteristics are not likely to change, are they?
The "characteristics" I think you are referring to are there to help define the shape of the object. The camera picks up quite a bit of other object with the same colour signature.
PaulS: Dump that sketch. Create one that does NOTHING but initialize the serial port, read the ping sensor, and print the value to the serial port.
I have done that using the exact same pins as in the sketch above. The sensor works fine and gives reliable distance output. To be fair, just running the example from the new ping library works fine as well.
So, your thread title is a lie? Just what IS your problem?
PaulS: So, your thread title is a lie? Just what IS your problem?
Are you a retard, why would you post such a negative and un-helpful comment?
I cannot get the ultrasonic to work in my sketch above, using the new ping library. I am not sure if there is a conflict with this and some of the other libraries I have included, or where else the problem may be.
GreyE30:
#include <Wire.h>
#include “utility/Adafruit_PWMServoDriver.h”
#include <SPI.h>
#include <Pixy.h>
#define swap(a,b) {
        int c = (a);
        (a) = (b);
        (b) = c;
Pixy pixy;
  Serial.print(" Blocks : “);
  Serial.print(” ");
      continue;
    Serial.print("Size : “);
    Serial.print(”, ");
    Serial.print("Ratio : “);
    Serial.print(” ");
      chosenBlock = idx;
      Serial.println(“Could not find desired object”);
     return;
  Serial.print(", X Value : “);
  Serial.print(”, Y Value : ");
  if (dist<distLimit)
    Serial.println("cm “);
    Serial.print(” FORWARD “);
    Serial.print(” BACKWARD “);
    Serial.print(” RELEASE ");
I would agree with everyone else here. There’s a LOT you could do better with that code. I sent you an email reply that fixes most of your sketch. But, I’d like to post here that it sounds like there’s a conflict with a timer. One of the pins you’re using with the ultrasonic sensor could be used as a timer for the motor or camera sensor. So, try using two pins that don’t have a timer attached, like pins 7 & 8.
That’s where I would start, clean up your code so it’s more understandable and logical, then try using different pins. Next, adopt an event-driven paradigm instead of the block mode programming style you’re currently using. Doesn’t work well for robots.
Tim
Thats great Tim, thanks for the pointers and email reply. A real help for possible direction to start looking.
I hope I can get this reviewed and improved soon.
GreyE30: Thats great Tim, thanks for the pointers and email reply. A real help for possible direction to start looking.
The camera uses SPI, which is uses pins 10-13. You're also trying to connect the ultrasonic sensor to pins 11 and 12. So, you have two things wired to the same pins, which of course will cause a problem. Always know what pins a shield uses and always try different pins if you ever have a problem. Even if a shield isn't connected to a pin, it could use a timer that's tied to a pin which could cause a conflict.
Tim
