Problem in adding the library to the IDE
Hello ppl, i got problem in adding new libaries to the ide. When i try to add it i get some error as,
Exception in thread “AWT-EventQueue-0” java.lang.ArrayIndexOutOfBoundsException: 3184
at sun.awt.shell.Win32ShellFolder2.getFileChooserIcon(Win32ShellFolder2.java:931)
at sun.awt.shell.Win32ShellFolderManager2.get(Win32ShellFolderManager2.java:277)
at sun.awt.shell.ShellFolder.get(ShellFolder.java:227)
at com.sun.java.swing.plaf.windows.WindowsLookAndFeel$LazyWindowsIcon.createValue(WindowsLookAndFeel.java:2206)
at javax.swing.UIDefaults.getFromHashtable(UIDefaults.java:199)
at javax.swing.UIDefaults.get(UIDefaults.java:144)
at javax.swing.MultiUIDefaults.get(MultiUIDefaults.java:47)
at javax.swing.UIDefaults.getIcon(UIDefaults.java:431)
at javax.swing.UIManager.getIcon(UIManager.java:732)
at javax.swing.plaf.basic.BasicFileChooserUI.installIcons(BasicFileChooserUI.java:237)
at javax.swing.plaf.basic.BasicFileChooserUI.installDefaults(BasicFileChooserUI.java:219)
at javax.swing.plaf.basic.BasicFileChooserUI.installUI(BasicFileChooserUI.java:135)
at com.sun.java.swing.plaf.windows.WindowsFileChooserUI.installUI(WindowsFileChooserUI.java:129)
at javax.swing.JComponent.setUI(JComponent.java:673)
at javax.swing.JFileChooser.updateUI(JFileChooser.java:1763)
at javax.swing.JFileChooser.setup(JFileChooser.java:360)
at javax.swing.JFileChooser.(JFileChooser.java:342)
at javax.swing.JFileChooser.(JFileChooser.java:301)
at processing.app.Base.handleAddLibrary(Base.java:2382)
at processing.app.Base$4.actionPerformed(Base.java:955)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266)
at java.awt.Component.processMouseEvent(Component.java:6263)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.Window.dispatchEventImpl(Window.java:2475)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Can anyone help me to get rid of this!!
Hi Ashuk,
Most of the time, this is because the libraries are not organized properly.
Maybe you might like to follow through this. http://extremecomputation.blogspot.sg/2013/08/how-to-build-simple-light-meter-using.html
