hi, currently im doing this project about balancing 3D inverted pendulum using web-camera on a moving cart . I'm on the implementation stage at the moment and would like to use arduino uno (all the modeling and simulation have been done in matlab simulink). so far i used openCV in C++ to measure the angle tilted by the pendulum and arduino uno to do the control (PID) .
problems
how can i interface between C++ and arduino (read the angle from C++)
is arduino uno capable of doing the PID calculations
in my design , the output should be the speed of the motors and position of the cart . how can I archive this in arduino ? would i need to implement two pid function
do i need to implement filter(kalman ) in the control..? as i have already implement one in the vision code (C++)
The easiest way is to use the serial interface you also use for programming the Arduino. What platform does the C++ code run on?
You haven't told us about the speed you want to achieve but in most situations this is answered with "yes".
Do you have a picture or drawing of your setup? Although I have some imagination about how this looks like I don't know exactly which motors or carts you're talking about.
How about posting your current code? We cannot answer this as long as we don't know more details about the project (see point 3).
hi , thanks for getting back .
-visual studio
i would like to archive the speed of just below 1sec, the inverted pendulum pendulum im going to balance has length of 1.5m
and weigh=0.7kg
Do you have a picture or drawing of your setup? Although I have some imagination about how this looks like I don't know exactly which motors or carts you're talking about.[/b] - the cart is made up of four omni wheels so that it can move in 3D and motor are dc How about posting your current code? We cannot answer this as long as we don't know more details about the project ,//control code// //Define Variable int MotorIN_A = 8; int MotorIN_B = 12; int MotorPWM = 11; // ENABLE to digital pin 11 int sensorPin = ; // input from C++ , im not sure what to put it here /working variables/ double PV, Output, Setpoint; double kp, ki, kd; double errSum, lastErr; void setup(){ //Controller Parameter kp = 0.0; ki = 0.0; kd = 0.0; pinMode(Motor_INA1, OUTPUT); pinMode(Motor_INB1, OUTPUT); pinMode(Motor_PWM, OUTPUT); pinMode(, INPUT); // im not sure what to put here } void loop(){ sensorValue = digitalRead(sensorPin); //read the value Setpoint = 0 ; //zero degree vertical upright compute(); // Find controller output //Send command to DC motor if(Output > 0) { analogWrite(MotorPWM, Output); CC(); } else if(Output<-0){ analogWrite(MotorPWM, -Output); CCW(); } else{ STOP(); } Motor Control Function void CC(){ digitalWrite(MotorIN_A,HIGH); digitalWrite(MotorIN_B,LOW); } void CCW(){ digitalWrite(MotorIN_A,LOW); digitalWrite(MotorIN_B,HIGH); } void STOP(){ analogWrite(MotorPWM, 0); digitalWrite(MotorIN_A,LOW); digitalWrite(MotorIN_B,LOW); } //Compute controller output by PID algorithm void compute() { /How long since we last calculated/ double dT = (double)(now - lastTime); //Our Sampling time /Compute all the working error variables/ double error = Setpoint - PV; errSum += (error * dT); double dErr = (error - lastErr) / dT; /Compute PID Output/ Output = kp * error + ki * errSum + kd * dErr; /Max 255, Min -255/ if(Output>255){Output = 255;} else if(Output <-255){Output = -255;} else{} /Remember some variables for next time/ lastErr = error; lastTime = now; } thanks
That probably means Windows. I'm the Linux guy so I'm not very helpful on the PC side for you. Find out how to access the serial interface from Visual Studio and how to send values to it.
and weigh=0.7kg
1 second is incredibly long in computer terms, so if you want to correct your values just once a second and Arduino is more than powerful enough. Although I doubt a bit that one second reaction time is matching your needs.
That doesn't help much. Please take a picture and post it. I cannot imagine how you can move in 3D with just 4 wheels.
What exactly do you expect to get from the "sensorPin"? Just an on/off value? What should it be used for? Where do you set PV? What do you want sensorValue to be used for?
