Problem in bit reading with pgm_read_byte()
I need to work with bit, and so i choice pgm style.
Why this code is not working as expected?
#include <avr/pgmspace.h> //for pgm_read_byte
const prog_uint8_t wcode[9] = {   // store in program memory to save RAM
			B10010000,
			B11100000,
			B01000010,
			B11010000,
			B00000000,
			B00000000,
			B01100100,
			B00000101,
			B10100000  //last 4 bit is not used
 for (byte x=0; x<9; ++x) {
    byte data = pgm_read_byte (&wcode[x]);   // fetch data from program memory
        for (byte y=0; y<8; ++y) {
            if (data & (1<<y)) {
                Serial.print("1");
	       Serial.print("0");
        Serial.println("");
    Serial.println("");
   Serial.println("");
    delay(15*1000);
This code return this bit sequence
00100000
10000100
01101001
00010011
00001100
10001011
10100000
10000010
11101111
You are missing the PROGMEM declaration:
const prog_uint8_t PROGMEM wcode[9] = {
Thank you. I’m sorry :blush:
Another question i have some function have a PROGMEM const like this
void sendCode2() {
	const prog_uint8_t PROGMEM wcode[9] = {   // store in program memory to save RAM
			B10000000,
			B11100000,
			B01000010,
			B11010000,
			B00000000,
			B00000000,
			B01100100,
			B00000101,
	useCode(&wcode);
void useCode(){
            //do some stuff with code
                Serial.print("1");
	       Serial.print("0");
As you can seeuseCode function hasn’t any param. What the correct method for passing “wcode” variable from sendCode() to useCode() ? I need to use pointers? How?
Sorry, is correct to use this code? (note the pointers)
void sendCode2() {
			B10000000,
			B11100000,
			B01000010,
			B11010000,
			B00000000,
			B00000000,
			B01100100,
			B00000101,
	useCode(&wcode);
void useCode(uint8_t *wcode){
                Serial.print("1");
	       Serial.print("0");
