I am facing this problem since two weeks. I have connected ir sensors at transmitter to know whether obstacle is present or absent. I send this message to receiver. I want to blink an led if message receiver at receiver end is “obstacle absent”. But led doesn’t work as I want. What is the problem in my code?
Here is my code
#include <VirtualWire.h>
byte message[VW_MAX_MESSAGE_LEN]; // a buffer to store the incoming messages
byte messageLength = VW_MAX_MESSAGE_LEN; // the size of the message
int LED =13;
int pin=11;
Serial.println("Device is ready");
// Initialize the IO and ISR
vw_setup(2000); // Bits per sec
vw_rx_start(); // Start the receiver
pinMode(LED,OUTPUT);
if (vw_get_message(message, &messageLength)) // Non-blocking
Serial.print("Received: ");
for (int i = 0; i < messageLength; i++)
Serial.write(message[i]);
Serial.println("");
if(digitalRead(pin)=="Received: obstacle absent")
digitalWrite(LED,HIGH);
if(digitalRead(pin)=="Received: obstaclepresent")
digitalWrite(LED,LOW);
delay(200);
So ,how the receiver read the input as obstacle absent or present.
Where does the input come from? The input from a digital pin will not be the string "Obstacle present" or the string "Obstacle absent". You print those when the radio receives them.
The radio library put the data in an array. You can make a string out of the data, and then use strcmp() to compare the array data.
char message[VW_MAX_MESSAGE_LEN + 1]; // a buffer to store the incoming messages
First, you need to provide room in the array for the NULL to make it an array. Second, you should change it's type to char.
Then, you need to lie to the function, and tell it that you are passing it an array of the right type:
if (vw_get_message((byte *)message, &messageLength))
Next, you need to add a NULL to the array.
{ // Existing start of if body
message[messageLength] = '\0';
if(strcmp(message, "obstacle absent") == 0)
// Nothing in the way...
I am newbie to Arduino,sorry to say, but I am not able to understand what you are trying to say. Can you please help me by code. What should be code for it.
