problem in coding
hello iwant to send data from two sensors one is lm35 and other heartrate through esp8266 i have a code which is giving error:exit status 1
a function-definition is not allowed here before ‘{’ token
please help
this is my code
#include<SoftwareSerial.h>
SoftwareSerial esp8266(2,3);
#define DEBUG true
Serial.begin(9600); ///////For Serial monitor
esp8266.begin(115200); ///////ESP Baud rate
//pinMode(11,OUTPUT); /////used if connecting a LED to pin 11
//digitalWrite(11,LOW);
sendData(“AT+RST\r\n”,2000,DEBUG); // reset module
sendData(“AT+CWMODE=2\r\n”,1000,DEBUG); // configure as access point
sendData(“AT+CIFSR\r\n”,1000,DEBUG); // get ip address
sendData(“AT+CIPMUX=1\r\n”,1000,DEBUG); // configure for multiple connections
sendData(“AT+CIPSERVER=1,80\r\n”,1000,DEBUG); // turn on server on port 80
float sense()
float sensetemp()
int val = analogRead(A0);
float mv = ( val/1024.0)5000;
float celcius = mv/10;
return(celcius);
float senserate()
oldvalue=newvalue;
newvalue= 0;
for(int i=0; i<64;i++)
newvalue +=analogRead(A0);
newvalue=newvalue/64;
if (oldvalue<threshold && newvalue>=threshold){
oldmillis=newmillis;
newmillis=millis();
timings[cnt%16]=(int)(newmillis-oldmillis);
int totalmillis=0;
for(int i=0;i<=16;i++){
totalmillis+= timings
  • int heartrate = {60000/(totalmillis/16)};*
  • Serial.println(heartrate,DEC);*
  • cnt++;*
    delay(10);
    int connectionId;
    void loop(){
  • /////////////////////Recieving from web browser to toggle led*
  • if(esp8266.find("+IPD,"))*
  • if(esp8266.available())*
  • delay(300);*
  • connectionId = esp8266.read()-48;*
  • if(esp8266.find(“pin=”))*
  • Serial.println(“recieving data from web browser”);*
    _ int pinNumber = (esp8266.read()-48)*10;_
  • pinNumber += (esp8266.read()-48);*
  • digitalWrite(pinNumber, !digitalRead(pinNumber));*
  • /////////////////////Sending data to browser*
  • else*
  • String webpage = “
    Hello World
  • espsend(webpage);*
  • if(sense()!= 0)*
  • String add1=“
    Temperature=
  • String two = String(sensetemp(), 3);*
  • add1+= two;*
  • add1+="&#x2103"; //////////Hex code for degree celcius*
  • espsend(add1);*
  • String add2=“
    heartrate=
  • String two = String(senserate(), 3);*
  • add2+= two;*
  • add2+=“BPM”; //////////Hex code for degree celcius*
  • espsend(add2);*
  • else*
  • String c=“sensor is not conneted”;*
  • espsend(c); *
  • } closeCommand+=connectionId; // append connection id*
  • String closeCommand = “AT+CIPCLOSE=”; ////////////////close the socket connection////esp command*
  • closeCommand+="\r\n";*
  • sendData(closeCommand,3000,DEBUG);*
  • //////////////////////////////sends data from ESP to webpage///////////////////////////*
void espsend(String d)
  • String cipSend = " AT+CIPSEND=";*
  • cipSend += connectionId;*
  • cipSend += “,”;*
  • cipSend +=d.length();*
  • cipSend +="\r\n";*
  • sendData(cipSend,1000,DEBUG);*
  • sendData(d,1000,DEBUG);*
    *//////////////gets the data from esp and displays in serial monitor/////////////////////// *
    String sendData(String command, const int timeout, boolean debug)
  • String response = “”;*
  • esp8266.print(command);*
  • long int time = millis();*
  • while( (time+timeout) > millis())*
  • while(esp8266.available())*
  • char c = esp8266.read(); // read the next character.*
  • response+=c;*
  • if(debug)*
  • Serial.print(response); //displays the esp response messages in arduino Serial monitor*
  • return response;*
float sense()
  float sensetemp()
Here you are trying to define a function inside another function, but the dialect of C the Arduino uses doesn't allow that.
