Hi everyone Im receiving a data by gps
for example
char lat[]="30.246687";
i need to change it to a double for calculations...
but when Im using
strtod()
I get 30.25
I need the whole number... what should i do?
for example
but when Im using
strtod()
I get 30.25
If you are thinking of GPS NMEA data,
Is not a normal floating point number. The format is DDMM.MMMMM, degrees and minutes. Use TinyGPS++ to parse the data.
See What Exactly Is GPS NMEA Data? - GPS World
If that is not GPS NMEA data, use the function atof() or atod() to convert the character string to a float or double.
you probably don't. that's what you see if you print it without asking for 6 digits after the decimal point
see what you get from
char lat[] = "30.246687";
double dLat = strtod(lat, nullptr);
Serial.println(dLat, 2);
Serial.println(dLat, 3);
Serial.println(dLat, 4);
Serial.println(dLat, 5);
Serial.println(dLat, 6);
void loop() {}
30.25
30.247
30.2467
30.24669
30.246686
30.2466869
note that double are really just float (IEEE 4 bytes representations) on 8 bit microcontrollers and so you won't have the exact digit at the 6th digit after the decimal point
Be aware that the 6th digit byond the decimal point is units of approx 10cm.
So the GPS would need to be a real good one to want to do calculations beyond that resolution.
Correction:
...note that double are really just float (IEEE 4 bytes representations) on 8 bit microcontrollers and so you won't have the exact digit at the 6th digit...
The location of the decimal point has nothing to do with the number of significant digits...
Indeed wrong wording
