Problem in defining the time alarm
i tried to upgrade the codes and apply it in my project.However, an error appeared.sorry i am new to arduino.i attached along the image of my problem.
Post your code.
Use code tags.
Do not post an image of your code.
I'd be worried about the "a function declaration is not allowed" error message.
#include <Time.h>
#include <TimeAlarms.h>
#include <Wire.h>
#include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
#include <LiquidCrystal.h>
#include <SD.h>	       // SD card Library
#include <SPI.h>
LiquidCrystal lcd(41, 39, 37, 35, 33, 31);	// LCD Pin
int irpin=32;	//	IR sensor Pin
char timedatebuf[65];  // Time and Date string buffer
int year4digit;  // 4 digit year
int buzzer=22;// initialize buzzer pin
lcd.begin(16, 2);
Alarm.alarmRepeat(8,30,0, MorningAlarm);  // 8:30am every day
Alarm.alarmRepeat(17,45,0, EveningAlarm);
  setSyncProvider(RTC.get);   // the function to get the time from the RTC
  if(timeStatus()!= timeSet)
     Serial.println("Unable to sync with the RTC");
     Serial.println("RTC has set the system time");
Serial.print("Initializing SD card...");
 pinMode(53, OUTPUT);
  if (!SD.begin(53)) {  // check if card is installed
    Serial.println("No SD Card present in module");
    return;
  Serial.println("SD Card Ready");
 pinMode (irpin, INPUT);
 pinMode (buzzer, OUTPUT);
  // create the alarms
  Alarm.alarmRepeat(10,10,0, MorningAlarm);  // 8:30am every day
  Alarm.alarmRepeat(17,45,0,EveningAlarm);
   tmElements_t tm;
 void MorningAlarm(){
 digitalWrite (buzzer, HIGH);
 delay(5000);
   tmElements_t tm;
Yup, there it is - don't try to declare a function inside another function.
okok.i saw the problem dy.thx thx
the buzzer dint produce sound when the time reach? anyone can help?
Post your code.
#include <Time.h>
#include <Wire.h>
#include <SPI.h>
lcd.begin(16, 2);
//create the alarms
 pinMode(buzzer, OUTPUT);
     Alarm.alarmRepeat(0,58,0,MorningAlarm);  // 8:30am every day
 void loop() {}
 delay(5000);
 digitalWrite (buzzer, LOW);
Duplicate thread - Buzzer can't produce sound when the time is set - Programming Questions - Arduino Forum
Other thread locked.
DO NOT CROSS-POST, CROSS-POSTING WASTES TIME.
