problem in esp8266-01 with arduino uno-control led
i have problem with esp8266-01 and arduino uno when i control LEDs with ip address, i controlled 3 LEDs
code work good, when i add LED number 4 esp8266-01 stay blink and the process does not end.
this with 3 LEDs
and this when i add LED number 4
#include "WiFiEsp.h"
// Emulate Serial1 on pins 6/7 if not present
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(6, 7); // RX, TX
#endif
char ssid[] = "**";            // your network SSID (name)
char pass[] = "****";        // your network password
int status = WL_IDLE_STATUS;
int Chambre1_LED = 2;
int Chambre2_LED = 3;
int Salon_LED = 4;
int Chambre3_LED = 5;
WiFiEspServer server(80);
// use a ring buffer to increase speed and reduce memory allocation
RingBuffer buf(512);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(8, OUTPUT);
  Serial.begin(115200);   // initialize serial for debugging
  Serial1.begin(9600);    // initialize serial for ESP module
  WiFi.init(&Serial1);    // initialize ESP module
  // check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue
    while (true);
  // attempt to connect to WiFi network
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network
    status = WiFi.begin(ssid, pass);
  Serial.println("You're connected to the network");
  printWifiStatus();
  // start the web server on port 80
  server.begin();
 leds();
void leds ()
  WiFiEspClient client = server.available();  // listen for incoming clients
  if (client) {                               // if you get a client,
    Serial.println("New client");             // print a message out the serial port
    buf.init();                               // initialize the circular buffer
    while (client.connected()) {              // loop while the client's connected
      if (client.available()) {               // if there's bytes to read from the client,
        char c = client.read();               // read a byte, then
        buf.push(c);                          // push it to the ring buffer
        // printing the stream to the serial monitor will slow down
        // the receiving of data from the ESP filling the serial buffer
        //Serial.write(c);
        // you got two newline characters in a row
        // that's the end of the HTTP request, so send a response
        if (buf.endsWith("\r\n\r\n")) {
          sendHttpResponse(client);
          salon();
          chamb1();
          chamb2();
          chamb3();
    // close the connection
    client.stop();
    Serial.println("Client disconnected");
void chamb1()
        // Check to see if the client request was "GET /H" or "GET /L":
        if (buf.endsWith("GET /O1")) {
          Serial.println("Turn led ON");
          digitalWrite(2, HIGH);   // turn the LED on (HIGH is the voltage level)
        else if (buf.endsWith("GET /F1")) {
          Serial.println("Turn led OFF");
          digitalWrite(2, LOW);    // turn the LED off by making the voltage LOW
void chamb2()
        if (buf.endsWith("GET /O2")) {
          digitalWrite(3, HIGH);   // turn the LED on (HIGH is the voltage level)
        else if (buf.endsWith("GET /F2")) {
          digitalWrite(3, LOW);    // turn the LED off by making the voltage LOW
void salon()
        if (buf.endsWith("GET /O3")) {
          digitalWrite(4, HIGH);   // turn the LED on (HIGH is the voltage level)
        else if (buf.endsWith("GET /F3")) {
          digitalWrite(4, LOW);    // turn the LED off by making the voltage LOW
void chamb3()
        if (buf.endsWith("GET /O4")) {
          digitalWrite(5, HIGH);   // turn the LED on (HIGH is the voltage level)
        else if (buf.endsWith("GET /F4")) {
          digitalWrite(5, LOW);    // turn the LED off by making the voltage LOW
void sendHttpResponse(WiFiEspClient client)
  // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
  // and a content-type so the client knows what's coming, then a blank line:
  client.println("Content-type:text/html");
  client.println();
  // the content of the HTTP response follows the header:
  client.print("The LED is ");
  client.print(5);
  client.println("
  client.println("
  /*client.println("Click <a href=\"/H\">here</a> turn the LED on
  client.println("Click <a href=\"/L\">here</a> turn the LED off
  // The HTTP response ends with another blank line:
  client.println();
void printWifiStatus()
  // print the SSID of the network you're attached to
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print where to go in the browser
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
help me
int Salon_LED = 4;
Are you positive that you can use all 4 of these pins?
You gave the pin a name. Why are you now not using the name?
That is NOT what the code does.
You have WAY more code than you need. The requests that turn pins on all contain "GET /O" and those that turn pins off all contain "GET /F". The next character in each request could have been the pin to turn on or off.
I don't no .
i change this now but the problem is stay
