How do i measure LPG and Smoke using MQ2 sensor?What is range of LPG and Smoke values in ppm?Here is my arduino code:
#define sensor A0
#define load_Res 35
#define air_factor 9.83
float SmokeCurve[3] ={2.3,0.53,-0.44}; // (x, y, slope) x,y coordinate of one point and the slope between two points
float LPGCurve[3] = {2.3,0.21,-0.47};
float Res=0;
float result;
float result1;
float air_quality;
float val;
//float SensorCalibration();
String myString = String(result);
String myString1 = String(air_quality);
//String myString2 = String(SensorCalibration());
String data;
String Home_id="CSLM1";
String device_id = "CSLS1";
int I_high=100;
int I_low=0;
int B_high=50;
int B_low=0;
Serial.println("");
int i;
float val=0;
// Serial.print("SMOKE:");
val=resistance(5,250);
Serial.println(val);
val = val/air_factor;
Res = val;
// Serial.println(val);
// return val;
Serial.print("Calibration done.");
Serial.print("Res=");
Serial.print(Res);
Serial.print("kohm");
delay(2000);
pinMode(5,OUTPUT);
float res=resistance(5,50);
res/=Res;
result=pow(10,(((log(res)-LPGCurve[1])/LPGCurve[2]) + LPGCurve[0]));
// result1=pow(10,(((log(res)-SmokeCurve[1])/SmokeCurve[2]) + SmokeCurve[0]));
Serial.print("LPG:");
Serial.println(result);
if(result>=0.4)
digitalWrite(5,HIGH);
Serial.println("GAS LEAKAGE");
digitalWrite(5,LOW);
////////////////////////////////SMOKE////////////////////////////////////
// SensorCalibration();
// Serial.println(result1);
// delay(1000);
// POST();
air_quality=((I_high-50)*(result-50))/(result-50);
// Serial.println(air_quality);
if(val<=100)
Serial.println("Fresh Air");
air_quality=((I_high-50)*(result-50))/(result-50)+50;
if(val>=101 && val<=200)
Serial.println("Satisfactory Air");
if(val>=201 && val<=350)
Serial.println("Poor Air");
float resistance(int samples, int interval)
int i;
float res=0;
for (i=0;i<samples;i++)
int adc_value=analogRead(sensor);
res+=((float)load_Res*(1023-adc_value)/adc_value);
delay(interval);
res/=samples;
return res;
Please help me.
Advance in thanks.
