Hi, I am trying to get receive data to computer using a USB to serial adapter( Model :CADYCE CA-US9) from a Arduino uno, I have send "I am Pradeep" but in the serial terminal I receive this "[����[���=55��[" .
Trouble shooting Performed till now:
tried to used different USB to serial adapter based on CH340G but got the same result.
Tried it using another Arduino in reset mode i.e. as a adapter , which works fine.
I need to send the command to printer via rs232 for printing the barcode, but the data that I am sending is getting converted to gibberish.
If you are saying that the simple sketch you listed, that just prints directly to the serial window in the IDE is resulting in gibberish, and you have the correct baud rate selected in the serial monitor so window, I have no clues.
The cable you have is USB on one end and RS-232 on the other.
Please draw a block diagram showing all the devices involved in whatever it is you are trying to do, and how they are hooked up that does not work.
Say more.
Also, if you don't have or aren't using PuTTY or CoolTerm or other terminal emulator, you may want to consider doing. It can make finding mistakes and reverse engineering things very much easier.
The adapter you listed cannot be connected to you Arduino. Read what the adapter is for: "USB to Serial Convertor operates as a bridge between one USB port & standard RS-232 serial port ". Your Arduino DOES NOT have an RS-232 connection. It only has a serial connection to your PC that uses USB connection.
The output of your adapter is a + and - voltage greater than 3 volts and up to 12 volts and is definitely NOT TTL which is 0 and 5 volts.
If you want to communicate from an Arduino to a RS232 device, you need something like SparkFun RS232 Shifter - SMD - SparkFun Electronics. It handles the required level conversion. You will have to look at the printer specs to see what is exactly required as there might be handshake involved.
No; you will need hardware. RS232 is not a protocol.
Just buy a new USB/Serial adapter that has TTL levels.
They've become incredibly cheap.
OTOH, many current "rs232" adapters actually seem to provide simply "inverted TTL", in which case a SWSerial solution might in fact be possible without risking damaged hardware.
