Hi there, I am trying to read moisture data from this sensor. The sensor uses Attiny44A as the uC. The sensor comes with everything preinstalled. But I was not able to establish I2C communication. I have also tried the I2C scanner but didnt find any I2C device attached. I finally recompiled the main.c file from the src folder and uploaded using arduino as ISP to the sensor. Yet I am facing the same problem. Everything uploads fine.The author Mr Miceuz has also written a blog on the operation of sensor over here. He has mentioned that for proper working the sensor must buzz twice which my sensor does. So I am sure it is working fine. As I am a mechanical engineering I am having a very limited background on embedded electronics. So I have no clue on where to start the debugging.Any guidance will be deeply appreciated. Thanks.
This is the output after burning the bootloader to the chip.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Nilesh\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.3.3/avrdude.conf"
Using Port : COM10
Using Programmer : stk500v1
Overriding Baud Rate : 19200
Setting bit clk period : 5.0
AVR Part : ATtiny44
Chip Erase delay : 15000 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 6 4 0 no 256 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 4096 64 64 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9207 (probably t44)
avrdude: erasing chip
avrdude: reading input file "0xFF"
avrdude: writing efuse (1 bytes):
Writing | ################################################## | 100% 0.03s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFF:
avrdude: load data efuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip efuse data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0b11010111"
avrdude: writing hfuse (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0b11010111:
avrdude: load data hfuse data from input file 0b11010111:
avrdude: input file 0b11010111 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xE2"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xE2:
avrdude: load data lfuse data from input file 0xE2:
avrdude: input file 0xE2 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "C:\Users\Nilesh\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.3.3/bootloaders/empty/empty_all.hex"
avrdude: writing flash (2 bytes):
Writing | ################################################## | 100% 0.09s
avrdude: 2 bytes of flash written
avrdude: verifying flash memory against C:\Users\Nilesh\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.3.3/bootloaders/empty/empty_all.hex:
avrdude: load data flash data from input file C:\Users\Nilesh\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.3.3/bootloaders/empty/empty_all.hex:
avrdude: input file C:\Users\Nilesh\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.3.3/bootloaders/empty/empty_all.hex contains 2 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.04s
avrdude: 2 bytes of flash verified
avrdude done. Thank you.
To read the data I used this code:
#include <Wire.h>
Wire.begin();
void writeI2CRegister8bit(int addr, int value) {
Wire.beginTransmission(addr);
Wire.write(value);
Wire.endTransmission();
unsigned int readI2CRegister16bit(int addr, int reg) {
Wire.write(reg);
delay(1100);
Wire.requestFrom(addr, 2);
unsigned int t = Wire.read() << 8;
t = t | Wire.read();
return t;
Serial.print(readI2CRegister16bit(0x20, 0)); //read capacitance register
writeI2CRegister8bit(0x20, 3); //request light measurement
delay(9000); //this can take a while
Serial.print(", ");
Serial.println(readI2CRegister16bit(0x20, 4)); //read light register
