I just noticed that you sending the values to your serial monitor every time loop() executes, but you are only updating the data from the serial buffer when data is new. If that doesn’t fix it I would try the following to debug.
flush the serial buffer at the end of init()
Change the while loop to an if statement and put everything (reading the buffer, printing) in the if block.
Get the number of bytes read and send it to the serial monitor
Print the raw data received to the serial monitor
clear out the old data so I know if I am seeing new data
something like this
#include <SoftwareSerial.h>
int sensorValue; // variable to store the value coming from the sensor
SoftwareSerial serial(9,10);
serial.begin(9600);
delay(1);
//flush serial buffers just in case, once it is working this probably isn't necessary and can be removed.
Serial.flush();
serial.flush();
char serialData[30];
int lf = 10;
unsigned char read1,read2,read3;
int temp_int; //temporary integer variable
char temp_string[40]; //temporary string variable
if(serial.available() >= 15) //change to if() and wait until a full message is available
//this might need to be >=14, I'm not sure
//while() can work, but if() seems more appropriate since you
//are waiting for something to happen, not executing code while
//something else if true. Maybe I'm being overly picky
// Find out how many bytes of data you are getting
temp_int = serial.readBytesUntil(lf,serialData, 15);
//Send the number of bytes to the serial monitor
sprintf(temp_string, "Number of bytes read: %d", temp_int);
Serial.println(temp_string);
//send the raw data received to the serial monitor
sprintf(temp_string, "%c %c %c %c %u", serialData[0], serialData[1], serialData[2], serialData[3], serialData[4]);
sprintf(temp_string, "%u %u %u %u %u", serialData[5], serialData[6], serialData[7], serialData[8], serialData[9]);
sprintf(temp_string, "%u %u %u %u %u", serialData[10], serialData[11], serialData[12], serialData[13], serialData[14]);
// Bring all your processing into the if() block
read1 = ((serialData[1]-'0')*100) + ((serialData[2]-'0')*10) +(serialData[3]-'0');
read2 = ((serialData[6]-'0')*100) + ((serialData[7]-'0')*10) +(serialData[8]-'0');
read3 = ((serialData[11]-'0')*100) + ((serialData[12]-'0')*10) +(serialData[13]-'0');
Serial.println(read1);
Serial.println(read2);
Serial.println(read3);
// Clear out old data
for (int i = 0; i < 30; i++) {
serialData[i] = 0;
read1=0;
read2=0;
read3=0;
Serial.flush();
serial.flush();
if that doesn’t solve it, I am stumped. Maybe put a switch input use that to trigger a read of the serial buffer after you know there is new data.
