Problem in Number counting in LCD
Hello Friends,
I am working with Arduino Uno. I am writing codes for counter with push buttons. I am using 16X2 lcd. In ascending order, whenever it writes greater than 10, it shows ," B= 10. (B is a variable). but when I run for descending order it counts like..
B= 10 (for 10)
B= 19 (for 09)
B= 18 (for 08) and so on.
The problem is, it shows some parts of previous values. I need to remove this error
I am adding my program....
Plz help me out..
Digital_Pulse_timer_2.ino (2.15 KB)
First, learn how to post your code using the code tags with the # button above the smiley faces. More people will look at it than if they have to download a .ino file.
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int Assend = 6;
const int Desend = 7;
const int Next = 8;
const int Go = 9;
const int Up = 0;
const int S = 0;
int A = 0;
int B = 0;
  pinMode(Assend,INPUT);
  pinMode(Desend,INPUT);
  //*************** set up the LCD's number of columns and rows:***************************
  lcd.begin(16, 2);
  lcd.setCursor(3, 0);
  lcd.print("RTA FURNACE");
  delay(2000);
  // clear screen
  lcd.clear();
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 0);
  // print the number of seconds since reset:
  // Set temperature in Degree Celcius
  lcd.print("Set Temperature");
  lcd.setCursor(0, 1);
  lcd.print("Ts = ");
  lcd.setCursor(6, 1);
  int Up= digitalRead(Assend);
  int Down= digitalRead(Desend);
  // For Temperature SET
  if(Up == HIGH) {
    Upcount();
  else {
    if(Down == HIGH) {
      Downcount();
void Upcount() {
  ++B;
  if(B > 9) {
    lcd.setCursor(5, 1);
  lcd.print(B);
  //Serial.println(B);
void Downcount() {
  --B;
  if(B < 10) {
    lcd.setCursor(4, 1);
  lcd.print(B);
You are a little off in your cursor positioning. Change the Downcount function to
void Downcount() {
  --B;
  if(B < 10) {
    lcd.print(" ");
    lcd.setCursor (5,1);
    lcd.print(B);
