problem in printing
my code
uint32_t value = 3600*10;
Serial.println(value);
value = 36000 * 1;
output
4294937760
36000
What did you expect when you multiply two sixteen bit signed integers?
Please remember to use code tags when posting code.
   uint32_t value = 3600UL*10;
   value = 36000 * 1;
output 36000 36000
3600 is an 'int' constant. When you multiply it by another 'int' constant you get an 'int' result EVEN THOUGH AN 'int' CAN'T STORE 36000 (0x8CA0 in hex). The result is truncated to 16 bits and treated as an 'int'. The value is then -29536. When casting the 'int' to 'unsigned long' the size is adjusted first, by sign extension: 0x8CA0 becomes 0xFFFF8CA0 As an unsigned long that evaluates to: 4294937760
36000 is a 'long' constant because the compiler knows it won't fit in an 'int'. The value in hex is 0x00008CA0
When you multiply a 'long' by an 'int' you get a 'long' result: 0x00008CA0 As an unsigned long that evaluates to: 36000
PaulS:
  value = 36000 * 1;
output
36000
36000
Sorry!..New to this forum. I’ll take care next time
Kudos to johnwasser for actually explaining what was happening.
johnwasser: 3600 is an 'int' constant. When you multiply it by another 'int' constant you get an 'int' result EVEN THOUGH AN 'int' CAN'T STORE 36000 (0x8CA0 in hex). The result is truncated to 16 bits and treated as an 'int'. The value is then -29536. When casting the 'int' to 'unsigned long' the size is adjusted first, by sign extension: 0x8CA0 becomes 0xFFFF8CA0 As an unsigned long that evaluates to: 4294937760
Thank you so much;-)
