problem in program I need your help
good morning
I have a problem with the program which I have made for controlling home appliances I have LDR, PIR, SOUND and TEMP DHT11 (3 pin) and 4 relay with Arduino Leonardo
first problem I cant see the temp value in the serial monitor
second it is working in the opposite way when it should be high it is low and the opposite correct so I made it opposite to work good and the temp relay it stay on only, please could you help me to correct the code.
final_LDR___PIR_ok__sound_and_temp.ino (1.74 KB)
Thanks..Tom... :)
it is so difficult but I will do
it takes some time
thanks
#include <dht11.h>
dht11 DHT11;
#define LDR A0
#define PIR 2
#define SOUND A1
#define DHT11PIN 7
  • AnalogReadSerial
  • Reads an analog input pin 1 and prints the result to the serial monitor
  • Click on the serial monitor button to open it.
#define RELAY_1 3
#define RELAY_2 4
#define RELAY_3 5
#define RELAY_4 6
int pirState;
int sensorValue;
int ldrValue;
DHT11.attach(4);
Serial.println(“Virtuabotix DHT11 FAN & Heater CONTROL”);
pinMode(RELAY_1, OUTPUT);
pinMode(RELAY_2, OUTPUT);
pinMode(RELAY_3, OUTPUT);
pinMode(RELAY_4, OUTPUT);
digitalWrite(RELAY_4, LOW);//turn off the relay
pinMode(PIR, INPUT);
digitalWrite(RELAY_1, HIGH);
pinMode(SOUND, INPUT);
void loop(){
ldrValue = analogRead(LDR);
//Serial.print("Analog reading = ");
//Serial.println(ldrValue);
if (ldrValue <= 512) { // dark
digitalWrite(RELAY_2, LOW);
else { // light
digitalWrite(RELAY_2, HIGH);
pirState = digitalRead(PIR);
if (pirState == LOW) {
else {
digitalWrite(RELAY_1, LOW);
delay(10000);
sensorValue = analogRead(SOUND);
Serial.println(sensorValue, DEC);
delay(10);
if (sensorValue <= 5) {
digitalWrite(RELAY_3, HIGH);
else {
digitalWrite(RELAY_3, LOW);
delay(10000);
Serial.println("\n");
int chk = DHT11.read();
Serial.print("Read sensor: ");
switch (chk)
Serial.print("Temperature (C): ");
Serial.println(DHT11.temperature, DEC);
if(DHT11.temperature < 30)//change to match your threshold in C.
digitalWrite(heatrelaypin, HIGH);//turn on the heater
digitalWrite(heatrelaypin, LOW);
delay(2000);
    switch (chk)Why switch and no cases ?
:) should I delete it ?
ok
Almawali: ok
Full marks for brevity :)
...R
