problem in program
Hallo,
I have a problem to put the program into my UNO
sence 27 say’s “stray in program” and I don not know what to do.
I am a Arduino user…not a ICT man…
So please see attachment for the problem and I hope you can help me in simple words.
greetings
Bob
zhtech@zhtech.nl
LiquidCrystal Library.doc (34 KB)
Hello Bob,
Would you be so kind to repost your code as per the following post ?
http://forum.arduino.cc/index.php/topic,148850.0.html
Before copying the program from the Arduino IDE' please do CTRL-T, or use the Auto Format from the Tools menu. That will improve the formatting of your code and will it easier for people to review.
Have you added the library as a ZIP file ? Also, would it be possible to know which version of IDE you are using ?
Cheers
dan
No, he attached a .doc file, with line numbers. Not the best to work with.
Probably the LiquidCrystal.h file is in the wrong place.
Bob, check File:Preferences, see where the path is. In that folder there needs to be a /libraries folder, LiquidCrystal.h needs to be in there.
LiquidCrystal Library - Hello World
1 /*
2  Luiquid cristal library - hallo world.
3  In this program, we use 2 switches to make a count increment
4   and decrement
5
6   * LCD RS pin to digital pin 7
7   * LCD Enable pin to digital pin 6
8   * LCD D4 pin to digital pin 5
9   * LCD D5 pin to digital pin 4
10 * LCD D6 pin to digital pin 3
11 * LCD D7 pin to digital pin 2
12 * LCD R/W pin to ground
13 * LCD VSS pin to ground
14 * LCD VCC pin to 5V
15 * 10K potentiometer:
16 *Black wire to Ground
17 *Red wire to VCC
18 *Green wire middle one to VEE
19 */
20 // swtich 1 connected at Pin 8 and other end to GND
21 // switch 2 connected at Pin 9 and other end to GND
22 // Refer Circuit
23
24 int sw1 = 8;  // Connect pin 8 to SW1
25 int sw2 = 9;  // Connect pin 9 to SW2
26 int count = 0;
27 #include <LiquidCrystal.h>              < [color=red]-  stray in program[/color]
28 // initialize the library with the numbers of the interface pins
29 LiquidCrystal lcd(7,6,5,4,3,2);
30
31 void setup()
32
33  // set up the LCD's number of columns and rows:
34  lcd.begin(16, 2);
35  // Print a message to the LCD.
36  lcd.print("Up-Down Counter");
37  // Declare Switches as INPUT to Arduino
38  pinMode(sw1,INPUT);
39  pinMode(sw2,INPUT);
40  digitalWrite(sw1,HIGH);
41  digitalWrite(sw2,HIGH);
42  }
43
44  void loop()
45 {
46  if(digitalRead(sw1) == LOW)   // if SW1 is pressed perform action describ
47  ed in loop
48 {
49   count++;                    // Increment Count by 1
50    lcd.setCursor(0, 1);
51    lcd.print(count);
52   delay(400);
53  }
54  if(digitalRead(sw2) == LOW)    // if SW2 is pressed perform action descri
55  bed in loop
56  {
57   count--;                     // Decrement Count by 1
58    if(count < 0)
59      count = 0;
60    lcd.setCursor(0, 1);
61  lcd.print(count);
62    delay(400);
63  }
64
65 }
I don’t have a standard LCD display, but use an I2C display from Yourduino. I’ve commented out the standard display code and substituted the code for the I2C display and it works fine.
//#include <LiquidCrystal.h>              < [color=red]-  stray in program[/color] ORIGINAL CODE
//#include <Wire.h>  // Comes with Arduino IDE
// Get the LCD I2C Library here:
// https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
// Move any other LCD libraries to another folder or delete them
// See Library "Docs" folder for possible commands etc.
/*-----( Declare Constants )-----*/
/*-----( Declare objects )-----*/
// set the LCD address to 0x27 for a 16 chars 2 line display
// A FEW use address 0x3F
// Set the pins on the I2C chip used for LCD connections:
//                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
int count = 0;
// LiquidCrystal lcd(7,6,5,4,3,2);            // ORIGINAL CODE
  lcd.begin(16, 2);
  pinMode(sw1,INPUT);
  pinMode(sw2,INPUT);
    lcd.print(count);
    delay(400);
    if(count < 0)
      count = 0;
    lcd.print(count);
    delay(400);
