Hello,
I'm trying to read the contents of the file inside a array.
For the first few lines it reads properly but after that it doesn't read the full line.
I'm attaching the file which i'm reading.
This is my code to read the file:
#include <SD.h>
///////// SD File Handler
File SD_File_Handler;
///////// Defining Global Constants
#define SD_CS 4
#define Meter_DB_File "meter_db.txt"
#define Config_File "config.txt"
#define Meter_DB_Max_Rows 40
///////// Defining Global Variables
uint8_t SD_Init = 0;uint8_t Config_Init = 0;uint8_t Meter_DB_Init = 0;
String Meter_DB_Rows[Meter_DB_Max_Rows];
void setup(){
while (!Serial) {;}
void loop(){
// If SD Card is not Initialized
if(SD_Init==0){
Serial.println("Initializing SD");
init_sdcard();
// If SD Card is Initialized, but Configuration Parameters not initialized
if(SD_Init==1 && Config_Init==0){
Serial.println("Initializing Config Variables");
init_config();
// If Configuration Parameters is Initialized
if(Config_Init==1) {
// If Meter DB File not Initialized
if(Meter_DB_Init==0){
Serial.println("Initialize Meters Details From DB File");
read_meter_db();
delay(100);
//Serial.println(Meter_DB_Rows[16]);
for (int k = 1; k < Meter_DB_Max_Rows; k++){
if(Meter_DB_Rows[k].length()!=0) {
//Serial.println(Meter_DB_Rows[k]);
//explode(Meter_DB_Rows[k],",");
delay(100);
process_meter(Meter_DB_Rows[k]);
delay(100);
///////// Initializing SD Card /////////////////
void init_sdcard() {
pinMode(SD_CS, OUTPUT);
if (SD.begin(SD_CS)) {
SD_Init = 1;
else {
SD_Init = 0;
void init_config() {
Config_Init=1;
void read_meter_db() {
/// opening file
SD_File_Handler = SD.open(Meter_DB_File);
if (SD_File_Handler) {
int i=0;
char row_ch;
String temp[]="";
while (SD_File_Handler.available()) {
////// Reading contents of the file
row_ch=SD_File_Handler.read();
////// Checking if end of line
if(row_ch=='\n'){
i++;
else {
Meter_DB_Rows[i]=Meter_DB_Rows[i]+row_ch;
Meter_DB_Init=1;
SD_File_Handler.close();
else {
Meter_DB_Init=0;
void process_meter(String Meter_Details) {
Serial.println(Meter_Details);
The output which i get is :
Initializing SD
1,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
2,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
3,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
4,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
5,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
6,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
7,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
8,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
9,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
10,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
19,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
27,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
29,0,0,FLOAT,0.0,286,2,INT,0,0.1,0
0
0
0
Can somebody please help me??
Thanks
meter_db.txt (1.18 KB)
