problem IN running DHT11 sensor
hello.
i want to run dth11 sensor with marlin code. i installed libraries and other stuff as instruction in github but i get below errors.
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
libraries\DHT-sensor-library\DHT_U.cpp.o (symbol from plugin): In function `DHT_Unified::Temperature::getEvent(sensors_event_t*)':
(.text+0x0): multiple definition of `DHT_Unified::Temperature::getEvent(sensors_event_t*)'
sketch\DHT_U.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `DHT_Unified::Humidity::getEvent(sensors_event_t*)'
(.text+0x0): multiple definition of `DHT_Unified::DHT_Unified(unsigned char, unsigned char, unsigned char, long, long)'
(.text+0x0): multiple definition of `DHT_Unified::begin()'
(.text+0x0): multiple definition of `DHT_Unified::setName(sensor_t*)'
(.text+0x0): multiple definition of `DHT_Unified::setMinDelay(sensor_t*)'
(.text+0x0): multiple definition of `DHT_Unified::Temperature::getSensor(sensor_t*)'
(.text+0x0): multiple definition of `DHT_Unified::Humidity::getSensor(sensor_t*)'
(.text+0x0): multiple definition of `DHT_Unified::Temperature::Temperature(DHT_Unified*, long)'
(.text+0x0): multiple definition of `DHT_Unified::Humidity::Humidity(DHT_Unified*, long)'
HardwareSerial0.cpp.o (symbol from plugin): In function `Serial':
(.text+0x0): multiple definition of `__vector_25'
sketch\MarlinSerial.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
option enabled in File -> Preferences.
These errors indicate that you put a copy of the library source files in your sketch folder in addition to the normally installed library.
Do this:
  • (in the Arduino IDE) Sketch > Show Sketch Folder
  • Delete all the files in the sketch folder that have "DHT" in their name. Please be very careful when deleting files from your computer. When in doubt, back up!
Now try compiling Marlin again
Thnaks it was helpful :wink:
You're welcome. I'm glad if I was able to be of assistance. Enjoy!
Per
another problem came up. :{
i want define DHT11 as bed temperature sensor. would you please help me?
