Problem in sending sensor reading through Mqtt
Hello
I am trying to send a sensor reading in packets of 100 data in Json format. Everything works very well but only for a certain time, suddenly I stopped receiving data from the broker
(HiveMQ). I am using an Arduino Nano 33 Iot card, for the Mqtt connection I tried the PubSubClient and ArduinoMqttClient libraries and with both I had the same problem.
This is the code:
#include <StreamUtils.h>
#include <StreamUtils.hpp>
#include <PubSubClient.h>
#include <ArduinoJson.h>
#include <ArduinoJson.hpp>
#include <SPI.h>
#include <WiFiNINA.h>
#include <WiFiSSLClient.h>
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = "###";  // your network SSID (name)
char pass[] = "###";             // your network password (use for WPA, or use as key for WEP)
WiFiSSLClient wifiSSLClient;
PubSubClient client(wifiSSLClient);
const char broker[] = "###########s2.eu.hivemq.cloud";
int port = 8883;
const char topic[] = "myTopic";
String Cov = "";
//const long interval = 500;
//unsigned long previousMillis = 0;
StaticJsonDocument<4096> doc;
long lastReconnectAttempt = 0;
boolean reconnect() {
  if (client.connect("arduinoClient")) {
    // Once connected, publish an announcement...
    client.publish("StatusSensor", "Reconnecting");
    // ... and resubscribe
    client.subscribe("topic");
  return client.connected();
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ;  // wait for serial port to connect. Needed for native USB port only
  // attempt to connect to WiFi network:
  Serial.print(F("Attempting to connect to WPA SSID: "));
  Serial.println(F(ssid));
  while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
    // failed, retry
    Serial.print(".");
    delay(3000);
  Serial.println(F("You're connected to the network"));
  client.setServer(broker, port);
  client.connect(broker, "Name", "Password");
  Serial.print(client.state());
  if (!client.connected()) {
    long now = millis();
    if (now - lastReconnectAttempt > 5000) {
      lastReconnectAttempt = now;
      // Attempt to reconnect
      if (reconnect()) {
    // Client connected
    JsonArray ArSensor1 = doc.createNestedArray("Sensor_1");
    for (int i = 0; i < 99; i++) {
      int var = analogRead(A0);
      for (int x = 0; x <= 1; x++) {
        ArSensor1.add(var);
    WriteBufferingStream bufferedWifiClient(wifiSSLClient, 64);
    serializeJson(doc, Serial);
    client.beginPublish(topic, measureJson(doc), 1);
    serializeJson(doc, bufferedWifiClient);
    bufferedWifiClient.flush();
    client.endPublish();
    doc.clear();
    delay(10);
    client.loop();
Hello I am trying to send a sensor reading in packets of 100 data in Json format. Everything works very well but only for a certain time, ... Create an instance of wificlient and pass it to the Word Master PubSubClient. The reconnect function above, connects the client to the MQTT server using the credentials provided. In the void loop, the sensor values from the LDR and the DHT are taken. On temperature values are taken from the DHT.Where is the MQTT server located? Is it on a machine in your own network or on a public machine? If it is on your own network are you using the public IP or the internal IP?
Check the mqtt log files. If you are using linux they will be in /etc/.
Try using a smaller amount of data.
Looks like your adding the same data point twice in ArSensor1 ? Is that what you are intending ?
The broker I use is privately hivemq. and I'm not using that type of sensor, but its response is analogous.
I have already checked the files without positive results, on the ArSensor question I use a nested "for" so that the array does not duplicate the value
