problem in serail communication with sim908 with arduino mega
I am trying to communicate with SIM908 module with Arduino mega 2560.
Module i am using has 232 port,so i am using 232 to TTL convertor to communicate..
My circuit connections are as follows:
Rx-Tx-0, Tx-Rx-0, GND-GND.
my code for making a call from sim908
int flag=0;
int flag2=0;
flag=sendATcommand("AT","OK",10000);
if(flag)
flag2=sendATcommand("ATD07354335501;","OK",10000);
if (flag2)
 delay(10000);
 sendATcommand("ATH","OK",10000);
int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout){
   uint8_t x=0,  answer=0;
   char response[100];
   unsigned long previous;
   memset(response, '\0', 100);    // Initialice the string
   delay(100);
   while( Serial.available() > 0) Serial.read();    // Clean the input buffer
   if (ATcommand[0] != '\0')
       Serial.println(ATcommand);    // Send the AT command
Serial.print(Serial.read());
   x = 0;
   previous = millis();
   // this loop waits for the answer
   do{
       if(Serial.available() != 0){    // if there are data in the UART input buffer, reads it and checks for the asnwer
           response[x] = Serial.read();
          // Serial.print(response[x]);
           x++;
           if (strstr(response, expected_answer) != NULL)    // check if the desired answer (OK) is in the response of the module
               answer = 1;
   }while((answer == 0) && ((millis() - previous) < timeout));    // Waits for the asnwer with time out
   return answer;
OUTPUT
AT
-1
I have sucessfully made call and send sms read gps NMEA data by sending command directly from computer using PuTTY software..
i have tried 2-3 convertors(232 to TTL)
since i am not using software serial i am uploading program by disconnecting module from arduino but still unsucessfull.
But i am not able to communicate it with it using arduino...
please help me finding what could be the possible mistake i am making... i am in the middle of a project but m stuck in this problem..
please help..
Thank you very much in advance....
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
