Problem in serial communication of mega2560 with sim800c
I connected an Arduino Mega2560 to a SIM800C module. when I program the Mega with a blank sketch, SIM800 module is responding to at commands using serial monitor (via pins 0,1). But when I connect it to other serial ports like serial1 the at commands was sent to SIM800 and it recieve and work (i sent some sms to my mobile no and recieved) but the response has some invalid characters. for example when i send AT, its response in hex format is like as bellow: 505548A848F80 (the string equivalent: PUH¨Hø)
#define gsm Serial2
String Arsp, Grsp;
  Serial2.begin(9600);
  if(gsm.available())
    //Grsp = gsm.readString();
    //char incomingByte;
    //incomingByte = gsm.read();
    // say what you got:
    //Serial.print("I received: ");
    //Serial.print(incomingByte, HEX);
    Serial.print(gsm.read(),HEX);
  if(Serial.available())
    Arsp = Serial.readString();
    Serial.print("Sent:");
    Serial.println(Arsp);
    gsm.println(Arsp);
Would anybody help me? Thanks
Good job using code tags on your first post. :slight_smile:
How is the Sim800 module connected to Serial2? What pins to what pins?
I connected Sim800 TXD to Mega RX2 and Sim800 RXD to Mega TX2 and GND to GND.
but Also I found that there is about 1.8V on mega rx2, rx3, rx1 and tx1, tx3 pin when those are offline. just the tx2 pin is 5V.
may be there is a problem?
I disconnected the mega completely and found that there is about 2V voltage on about all I/O pins?!!!
Could anybody guess where is the problem.
The question is that if the board has a problem why arduino IDE can detect and program the board without any problem?
After a Serialx.begin(), the RX and TX pins of the Mega should idle HIGH.
You are probably measuring floating pins.
The Sim800 is 3.3v. Are you using level shifters or a voltage divider, or is the module on some sort of shield/board which can interface directly with the 5v TTL serial of the Mega?
Thanks for your reply.
I Found that SIM800C UART2 is working. may be there is a problem with UART1. But for my knowledge:
cattledog:
The Tx pin is high but Rx is about 1V floating and 2.8V connected to SIM800 TXD pin.
cattledog:
I think that floating pin voltage should be 0V. is this true?
cattledog:
I devided SIM800 RX pin by 1K and 2.2K(to GND). but GSM TX pin is directly connected to Mega Rx directly.
The 2.8v is not high enough to guarantee a HIGH reading by the Mega. The spec for a guaranteed HIGH is .6 Vcc.(3v) Try adding an external pullup to 3.3v on this line? If this doesn't work you really should use a bidirectional level shifter.
This is correct.
No, a floating pin is undefined and can read any value which often moves around.
Many thanks for your Guidance.
