Problem in solving mathematical operation involving float.
Hey guys.
I am currently developing a project using Arduino Uno. One of the functions requires solving a mathematical operation. So, I try to TEST the program contains only the math “part”.
Here is my code:
#include <math.h>
float pointerX;
float FileSizeX;
unsigned long LoopX;
float WriteBiasa;
float DigitX;
unsigned int Vax;
  FileSizeX = 245;
  pointerX = 85;
  LoopX = pointerX/20;                        //i need the answer in whole number
  DigitX = pointerX/20;
  WriteBiasa = (DigitX - (float)LoopX)*20;
  Serial.print("\nLoopX :");
  Serial.print(LoopX);
  Serial.print("\nWriteBiasa :");
  Serial.print(WriteBiasa);
  Vax = fabs (WriteBiasa);
  Serial.print("\nVax:");
  Serial.print(Vax);
  Vax = int (WriteBiasa);
  Serial.print(Vax);
  LoopX = (FileSizeX-(pointerX+11))/20;
  DigitX = (FileSizeX-(pointerX+11.0))/20.0;
  WriteBiasa = (DigitX - (float)LoopX)*20.0;
  Serial.print(Vax);
  Serial.print(Vax);
The result of the code is as attached.
I’m quite confused here, is there anything wrong with how I wrote my program.
It keeps on showing the wrong result, when I try to convert float to int using both methods (fabs() and int()).
And I noticed it only happen when the result is 9 as the ones. (e.g. 9,19).
I really appreciate any help as I am new to Arduino software. TQ very much.
What are you trying to achieve?
input?
output?
The idea is to prove my “mathematical operation” works.
The mathematical problem is as follows:
/Fixed Inputs**/
  1. FileSizeX = 245;
    pointerX = 85;
/Mathematical Operation**/
1st Set–> LoopX = pointerX/20;
2nd Set–> LoopX = (FileSizeX-(pointerX+11))/20;
/Answer Needed in (int)***/
1st Set–> LoopX = 4
WriteBiasa = 5
2nd Set–> LoopX = 7
WriteBiasa = 9
/Answer Given in (int)***/
1st Set–> LoopX = 4
WriteBiasa = 5
2nd Set–> LoopX = 7
WriteBiasa = 8
  • The mathematical operation involves float numbers, but the final answers are needed in (int).
    However, converting from float to int (e.g.: from (float) 9.00 to (int)) for certain number produces a wrong answer.
Actually what your are doing is calculating the rest of a division
1st Set--> LoopX = pointerX/20;
WriteBiasa is the rest of the division of pointerX by 20, that you can simply write
int FileSizeX = 245;
int pointerX = 85;
int WriteBiasa = pointerX % 20;
2nd Set--> LoopX = (FileSizeX-(pointerX+11))/20;
Similarly, you can write
WriteBiasa = (FileSizeX-(pointerX+11)) % 20;
Thank you for your help. I really appreciate it. I have to admit it really blown my mind how simple that program can be written. Hahaha..
Still need to learn a lot..
Anyway, THANKS again!
