Problem in transfer data from arduino to Mysql database using ethernet shield
Please help me master :slight_smile:
i have got a problem in transferring data from arduino uno to Mysql database (i am using php)
i use ethernet shield to transfer data from client to server
i’m using Xampp, i have local network … no internet connection.
according to this link: http://thegeekforge.com/index.php?/archives/4-Arduino-Ethernet,-POST-to-PHP-to-MySQL.html
Here is my project :
  1. update.php
<?php
require("config.php");
// You need to create a table on your MySql server database. Here it is called 'MY_TABLE'.
              // You will also have to define fields in the table.
             //I happen to name my fields the same as my POST variables.
$query = "INSERT INTO monitoring(irms1,irms2,irms3)
                  VALUES('$_POST[irms1]', '$_POST[irms2]', '$_POST[irms3]')";
 if(!@mysql_query($query))
echo "&Answer; SQL Error - ".mysql_error();
 return;
[/code
2. config.php
[code]
<?php
$dbhost = 'localhost';
$dbuser = 'root';
$dbpass = '';
$dbname = 'edwin';
$conn = mysql_connect($dbhost, $dbuser, $dbpass) or die ('Error connecting to mysql');
mysql_select_db("edwin");
  1. arduino sketch
#include <SPI.h>
#include <Ethernet.h>
int irms1;
int irms2;
int irms3;
String txData ="";
byte mac[]     = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[]      = { 192,168,1,9 };
byte gateway[] = { 192, 168,   3,  1 };
byte subnet[]  = { 255, 255, 255,   0 };
  Ethernet.begin(mac, ip);
  irms1 = analogRead(A0);
  irms2 = analogRead(A1);
  irms3= analogRead(A3);
 txData = "i1="+ (String (irms1)) + "i2="+ (String (irms2)) + "i3="+ (String (irms3));
 EthernetClient client;
if (client.connect("192.168.1.100",80))
    Serial.println("Connected to server...");
 client.print("POST /update/update.php HTTP/1.1\n");
 client.print("Host: server\n");
   client.print("Connection: close\n");
   client.print("Content-Type: application/x-www-form-urlencoded\n");
   client.print("Content-Length: ");
client.print(txData.length());
   client.print("\n\n");
    client.print(txData);
   Serial.println("Connection Failed.");
 delay(5000);
screenshot of serial monitor
https://images-blogger-opensocial.googleusercontent.com/gadgets/proxy?url=http%3A%2F%2F2.bp.blogspot.com%2F-zcxYQUgG994%2FU4QBL8FwqjI%2FAAAAAAAAByU%2FvHzprhy_SXo%2Fs1600%2F1.bmp&container=blogger&gadget=a&rewriteMime=image%2F*
the database of mysql dont update
Please help me XD
[/code]
The first thing I see is you forgot the ampersands (&) in the POST data.
 txData = "i1="+ (String (irms1)) + "&i2="+ (String (irms2)) + "&i3="+ (String (irms3));
The server generates some kind of reply. Why are you not reading that? A clue just might present itself.
