Problem in understanding HC-SR04 Ultrasonic Sensor
Is it necessary to feed 10 microsecond High to Low pulse to trig pin of HC-SR04 ultrasonic sensor. I have tried I have tried less than 10 and more than 10 microseconds pulse and they also work fine for me. Every datasheet that i read says we have to feed aleast 10 microseconds TTL pulse to HC-SR04. So i don't understand whats the point in 10 microseconds if it works in other conditions as well.
The duplicate topic has been deleted
Cross posting warning
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
All of the data sheets that I have seen say trigger pulse width is 10us minimum. It may work with a narrower pulse but it is out of specification. The device is actually triggered on the negative edge (transition) so as long as the width meets the minmum, the unit should work.
