problem in understanding the hmc5883l output
Hello ppl,
i am new to arduino. I am using magnetometer HMC 5883l. i am using the code given in sparkfun: SparkFun Triple Axis Magnetometer Breakout - HMC5883L - SEN-10530 - SparkFun Electronics. can someone tell me what exactly is the output of this sensor??? its like x=55, y=87, z=92. what are these readings radians or Gauss???? My application is to find magnetic field strength.
Can anyone help me???
Thanks
Datasheet says 12 bit outputs achieve 2mG resolution in +/- 8G range (ie the numbers are likely multiples of 2mG resolved in the appropriate axis. Earth's field is between 0.25 and 0.6G roughly depending on location. Your values indicate 0.276G
how did you calculate 2.76G??
No idea, but I know how I calculated 0.276G :wink:
LSB = 2mG
x = 55 = 110mG
y = 87 = 174mG
z = 92 = 184mG
sqrt(x^2+y^2+z^2) = 276mG = 0.276G
