problem in uploading program
hi,
iam using arduino uno connected with HC 05 bluetooth module.
the program from ide is not uploading to uno.
i get these error messages.anyone plz help me
Arduino: 1.8.1 (Windows 8.1), Board: "Arduino/Genuino Uno"
Sketch uses 926 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
An error occurred while uploading the sketch
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
option enabled in File -> Preferences.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Have you got the bluetooth disconnected from the UNO?
Tom... :slight_smile:
Is your Bluetooth Module connected to the Arduino when you try to upload? If so, just disconnect the RX pin, upload, then reconnect and reset. That should solve the problem because you need the TX/RX lines open to upload. Hope this helps.
