Problem in Uploading Sketch in Arduino Uno
Hi, I'm using arduino for around 3-4months. Now I'm facing issue in uploading sketch in arduino Uno.
This happened after using atmel-ice for debugging. I was trying to debug the code using atmel-ice for the first time in atmel studio. I followed tutorial video on YouTube for connecting and debugging arduino uno using atmel-ice debugger. Tutorial It never started debugging it turned off with an error. After that I tried to upload sketch in board using arduino ide as well as atmel studio and using ice also but it cannot upload the sketch and in atmel studio I could read the device signature previously after trying debugging, I cannot read the device signature. I never touched the fuse settings in the atmel studio for arduino. It was default.
         avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Saurabh\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM12
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x08
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x08
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x08
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x08
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x08
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x08
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x08
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x08
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x08
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x08
avrdude done.  Thank you.
Getting above errors. in arduino ide. I read similar issues with others some of them were saying it is in debugging mode. But after restarting it should go out of that as uno resets. I've also checked loopback it's working. This happend with my 3 of uno boards I've only 1 left now. How can I solve the issue. I tried burning boot loader also but that also got error.
It may be a cable or driver problem. Read this. Try to use a better cable.
Sure. Tried that too. I can program the other boards using same cable. I tried arduino to arduino bootloader flashing/program flashing Got some real errors.
C:\Users\Saurabh>C:\Users\Saurabh\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Saurabh\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -F -patmega328p -cstk500v1 -PCOM11 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
         Using Port                    : COM11
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0xffffff (probably .avr8x_mega) (retrying)
Reading | ################################################## | 100% 0.05s
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATmega328P is 1E 95 0F
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as FF
avrdude: safemode: efuse reads as FF
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.02s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x00 != 0x3f
avrdude: verification error; content mismatch
avrdude: safemode: Verify error - unable to read hfuse properly. Programmer may not be reliable.
avrdude: safemode: Sorry, reading back fuses was unreliable. I have given up and exited programming mode
Then using -F tried to override it attached file for errors.
withoutCheckingDeviceSignature.txt (3.31 KB)
