Problem in uploading sketch in nano in arduino web editor
When i try to upload sketch in my nano using arduino wed editor , the sketch complied correctly , but follow error is shown while uploading .
Programming with: Serial
Flashing with command:C:/Users/Somnath/.arduino-create/arduino/avrdude/6.3.0-arduino9/bin/avrdude.exe -CC:/Users/Somnath/.arduino-create/arduino/avrdude/6.3.0-arduino9/etc/avrdude.conf -q -q -patmega328p -carduino -PCOM9 -b115200 -D -Uflash:w:C:/Users/Somnath/AppData/Local/Temp/arduino-create-agent143073390/Wash_Room_Light_Sw.hex:i
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6d
Incidentally when I upload sketch in my Uno , it does it successfully .
I am running windows 10 with latest version of firefox browser.
Hello,
Did you select the correct model of the board?
If BOTH all the COM PORT and the BOARD and the FLAVOUR < ( if needed) are correct there should not really be any issue.
Other problems could arise from USB 3.0 ports, Antivirus, Incorrect plugin installation/corruption, bad USB cable and a few more common things.
