Problem include library softwareSerial
My code:
Prova.ino :
#include "ll.h"
#include "ll.cpp"
#include "ini.h"
#include <SoftwareSerial.h>
mySerial.begin(9600);
ll.h
#ifndef LL_H
#define LL_H
SoftwareSerial mySerial(2,3);
#endif
ll.cpp
#include "ll.h"
#include "ini.h"
ini.h
#ifndef INI_H
#define INI_H
#endif
ini.cpp
#include "ll.h"
#include "ini.h"
Error:
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
ll.cpp.o: In function __static_initialization_and_destruction_0': /ll.h:6: multiple definition of mySerial'
ini.cpp.o:/ll.h:6: first defined here
prova.cpp.o: In function loop': C:\Program Files (x86)\Arduino/prova.ino:12: multiple definition of mySerial'
I can not get out of this situation, I have to call "myserial" from various parts.
Tanks
You must NOT create instance of classes in header files. You declare variables in header files. You initialize them in source files.
You are far better off declaring mySerial in the sketch, and passing a reference or pointer to it to the constructor of your class.
PaulS:
Thanks for the reply, I understand what the problem is.
Could you give me an example of how to pass mySerial?
Thanks
My code:
prova.ino
#include "ll.h"
SoftwareSerial mySerial(2, 3);
rs_485 rtx_485; //Inizializza la classe
rtx_485.rxd(mySerial.read());
ll.h
#ifndef LL_H
#define LL_H
#include <arduino.h>
class rs_485
private:
public:
rs_485(); //Costruttore
void rxd(byte rx);
void txd(); //not work
#endif
ll.cpp
#include "ll.h"
//Costruttore
rs_485::rs_485()
void rs_485::rxd(byte rx)
void rs_485::txd()
mySerial.write(2); //Not work
error:
ll.cpp: In member function 'void rs_485::txd()':
ll.cpp:16: error: 'mySerial' was not declared in this scope
See if something like this works for you. I have put the class in the same file as the program for convenience; you should be able to move it into the library files.
The instance of SoftwareSerial is passed to the constructor as a reference.
You had not shown the definition of rxd and txd, so I have assumed they should work like read and write methods on serial - rxd returns one byte or -1 if none available, txd sends one byte. You may want to add an available method.
Note: compiles OK but not tested.
class rs_485
  private:
    SoftwareSerial& _port;
  public:
    rs_485(SoftwareSerial& port): _port(port)
    int rxd()
      if (_port.available())
        return _port.read();
        return -1;
    void txd(byte b)
      _port.write(b);
SoftwareSerial mySerial(3, 4);
rs_485 myRS485(mySerial);
:smiley: Grazie, adesso funziona!
Thank you, now it works!
