problem including if statement into clock code
I want my code to turn a servo when the serial monitor displays a certain time and I can’t seem to get my code to work…
I would greatly appreciate any help!
I’m really new to Arduino so this may be a pretty simple question.
Thanks so much!
  • Evan
#include <Time.h>
#include <TimeLib.h>
#include <Servo.h>
Servo myservo;
int pos;
  myservo.attach(9, 500, 2500);
  setTime(9, 0, 1, 29, 12, 20);
  digitalClockDisplay();
  if ( Serial.print(hour()) = 9 ) && (Serial.print(minute()) = 00) && (Serial.print(second()) = 00 ) ) {
    for (pos = 0; pos <= 110; pos += 1) {
      // tell servo to go to position in variable 'pos'
      myservo.write(pos);
      // wait 30 ms for servo to reach the position
      delay(30);
    for (pos = 110; pos >= 0; pos -= 1) {
      myservo.write(pos);
      delay(30);
void digitalClockDisplay()
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
void printDigits(int digits)
  Serial.print(":");
  if (digits < 10)
    Serial.print('0');
  Serial.print(digits);
clock_and_servo.ino (1006 Bytes)
Oops...
Also: the number of curly braces doesn't match!
ah true the curly brackets were off!
But also I'm not sure what the problem is with the line you mentioned. That was the one I was having problems with but I'm not sure how to fix it...
If you could point me in the right direction that would be fantastic!
Thanks so much!
evanbrorby:
You need to use == not = in an if(), thus:
if ( Serial.print(hour()) == 9 )
... not:
I count 9 ) and 10 (
Serial.print() returns the number of bytes printed, so you are comparing 9 (from your example) to the number of bytes sent to the serial monitor, not to the hour. You need to do the comparison separately from the print:
if (hour == 9) {
  Serial.print...
  Etc
That's a good spot....
