Problem inserting the code for LDR in this code
Hi! I'm a highschool student. We're trying to make an alarm on where when the LDR senses the light, the buzzer will create noises on these specific keys while the LEDs are on but I'm having some difficulty figuring out where to insert the code for the LDR in this one.
const int buzzerPin = 9;
pinMode (buzzerPin, OUTPUT);
tone(buzzerPin, 587, 709.720327982);
delay(788.578142202);
tone(buzzerPin, 554, 709.720327982);
tone(buzzerPin, 493, 273.683002294);
delay(304.092224771);
tone(buzzerPin, 369, 273.683002294);
tone(buzzerPin, 369, 134.52215367);
delay(149.469059633);
tone(buzzerPin, 493, 134.52215367);
tone(buzzerPin, 440, 134.52215367);
tone(buzzerPin, 391, 412.843850917);
delay(458.715389908);
tone(buzzerPin, 391, 134.52215367);
tone(buzzerPin, 554, 134.52215367);
tone(buzzerPin, 587, 273.683002294);
tone(buzzerPin, 440, 412.843850917);
tone(buzzerPin, 440, 41.7482545872);
delay(46.3869495413);
tone(buzzerPin, 440, 37.109559633);
delay(41.2328440367);
tone(buzzerPin, 587, 134.52215367);
tone(buzzerPin, 587, 46.3869495413);
delay(51.5410550459);
delay(30.9246330275);
delay(20.6164220183);
tone(buzzerPin, 659, 134.52215367);
tone(buzzerPin, 659, 273.683002294);
tone(buzzerPin, 554, 691.165548165);
delay(767.961720183);
tone(buzzerPin, 587, 552.004699541);
delay(613.338555046);
tone(buzzerPin, 554, 552.004699541);
tone(buzzerPin, 493, 46.3869495413);
Thank you for your time!
(This code isn't mine)
What on earth are all these precise delays etc....
looks like someone used an online calculator
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Forget the code you have there as it will only cause you problems.
First work on getting the LDR to input to the controller.
What model Arduino controller do you have?
This will help you understand how to do it.
https://create.arduino.cc/projecthub/tarantula3/using-an-ldr-sensor-with-arduino-807b1c?f=1
Get this working then google arduino buzzer code
What is the buzzer you have?
Thanks.. Tom.. :slight_smile:
Then why did you claim that it is the code you are using?
It is really simple to insert the code for the LDR in that code. Let's assume that the LDR is connected to analog pin 3.
   int ldrValue = analogRead(3);
   // The rest of your code with the silly delays goes here
Now, doing something with the value read from the pin is a whole different story. But, you seem to have forgotten to say what your requirements are.
Cams1113:
All those decimals do precisely nothing as they'll be discarded upon compilation. This as these functions only take integer values...
