Problem Installing DFRobot_TCS34725 library
Hello,
I'm slightly new to arduino.
I am making a project with the DFRobot TCS34725 Colour Sensor.
To use it, I tried including the library DFRobot gives at the bottom of this webpage:
https://www.dfrobot.com/wiki/index.php/TCS34725_I2C_Color_Sensor_For_Arduino_SKU:_SEN0212
However, when I did it, the Arduino IDE says that the zip file contains no library.
(Firstly I had to change the file DFRobot gives from .rar to .zip)
Could anyone try this to see if I am doing anything wrong?
Thank you in advance.
*sorry if I made any english grammar mistakes, I am not english native.
If i have not explained myself, please tell me.
kona:
How did you do that? You must have messed it up somehow during that process.
You should be aware that you can also manually install libraries, as explained here:
the "Add .ZIP library" installation method is convenient when the library is correctly packaged in a .zip file but if you have to go through all the trouble of creating a .zip file just to do the installation it's probably easier just to do a manual installation instead.
It's unfortunate that DFRobot doesn't have more care for their customers to make the library easier to install.
Thank you Pert for your early answer.
I had converted the file in a wrong way apparently. (I did: send to-- .zip file)
Now I tried an online .rar to .zip converter and it seems to have worked.
But yeah, don't understand why dfrobot gives the compressed file in .rar.
Thanks
