Hello, I am trying out Lesson 12 DHT11 Temperature and Humidity Sensor of the tutorial for mega 2560. Unfortunately, when I try to install the DHT library by including the zip file in the CD, I got the following message -
Error: 13 INTERNAL: Library install failed: archive is not valid: multiple files found in zip file top level
I installed DHT Sensors Non-Blocking from the library manger but I still got the compilation error -
#include <dht_nonblocking.h>
compilation terminated.
exit status 1
Compilation error: dht_nonblocking.h: No such file or directory
The instruction says so "After wiring, please open the program in the code folder- Lesson 12 DHT11 Temperature and Humidity Sensor and click UPLOAD to upload the program. See Lesson 2 for details about program uploading if there are any errors.
Before you can run this, make sure that you have installed the < DHT> library or re-install it, if necessary. Otherwise, your code won't work.
For details about the tutorial on the loading of library file, see Lesson 1."
Post the code copied from the lesson folder, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
It is also helpful to post error messages in code tags as it makes it easier to scroll through them and copy them for examination
